Author Topic: NanoVNA Custom Software  (Read 515272 times)
Offline realfran
Re: NanoVNA Custom Software
« Reply #1775 on: February 25, 2022, 07:01:25 pm »
One other thing I noticed was the sweep rate slow from 10Khz to 400Khz passing this limit start fast.
My observation is with the V.2.8
« Last Edit: February 25, 2022, 07:04:06 pm by realfran »
Offline joeqsmithTopic starter
« Reply #1776 on: February 25, 2022, 08:15:41 pm »
Sweep rates are dictated by the firmware, not the software and it's really up to Dislord to decide how he wants it to work.
From the last post, I assume this is what he plans to release:
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg4024105/#msg4024105
I can let the firmware try and squeeze every drop out while I wait or I can use the original NanoVNA to collect the data in a few minutes and have even higher performance.
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg4026451/#msg4026451
The following users thanked this post: realfran
Offline jspencerg
« Reply #1777 on: February 25, 2022, 10:48:28 pm »
Hello,
I suggest you remove the V2plus4 from your program header.  Do something to emphasize to new program user that you are in process of tailoring program to the LiteVNA. Previous recommendations of the V2Plus4 should be tempered with your current intentions.  You don't owe users anything, but fair warning of future program changes makes some sense.
I'm getting perspective about the nanovna  ecosystem as I read through this thread.
« Reply #1778 on: February 25, 2022, 11:54:15 pm »
Hello,
The header indicates which hardware is supported.   For now, this will be the V2Plus4 and the Lite.  It's not really tailored to one or the other.  It just happens that that V2Plus4 is falling far behind in features.  It sounds like from Dislord's comment that could be addressed easy enough if the developers decided to open it up.  If they do, it's up to the firmware developers to follow Dislords efforts if they want my software to support them.   The same holds true for any future products.  It's up to the developers to make their firmware compatible with the software, if they want to leverage it.
Because 3.x is so different from previous versions I have created a new repository for it.  I have no plans to do anything more with the original repository.   The 32-bit code will remain for those wanting to run on older OSs.
Offline jspencerg
« Reply #1779 on: February 26, 2022, 12:46:07 am »
I thought I'd seen you running current program version with the original nanovna...
So, version 3 will not support the v2plus4? I guess I'll stop reading about the new features with a sense of anticipation.
Thanks for the details.  I realize it's all in the works. I'll stop asking for predictions
« Reply #1780 on: February 26, 2022, 12:54:01 am »
I haven't made any updated to the software for the original NanoVNA since the last release.
Getting an early start?   :-DD
Offline realfran
« Reply #1781 on: February 26, 2022, 02:16:03 pm »
For me, the V2plus4 with the close firmware is a great disappointment no possibility to upgrade it, the Lite with the V.3 software is very interesting, especially for use with PC, I need to find some information for the calibration kit, the way to put Kurt calibration Kit data on the software. To calibrate one instrument need one calibration standard the professional one is very expensive out of my possibility. I hope to find someone nearby in the UK with professional VNA to help me to characterize one kit.
« Reply #1782 on: February 26, 2022, 07:30:39 pm »
Dislord,
Any idea what was changed in LiteVNA64-220225.BIN?   If this contains your most recent changes, can you provide where you ended up with the filter settings.
Last I knew, this was your proposed settings with E0 & E1 defaulting to 15 decimal:
< 20kHz
RBW=6k/(E0 * AVG)
20k - 400k
RBW=12k/(E0 * AVG)
400k - 100M
RBW=60k/(E0 * AVG)
> 100M
RBW=60k/(E1 * AVG)
« Last Edit: February 26, 2022, 07:38:49 pm by joeqsmith »
« Reply #1783 on: February 26, 2022, 07:48:35 pm »
I have heard of the low cost Kirkby kits but not Kurt.
https://www.kirkbymicrowave.co.uk/Sales-and-Services/Vector-network-analyzer-calibration-kits/SMA-calibration-kit/
As long as they provide the coefficients with the kit, you should be able to just type them in and hit save.
Offline DiSlord
  • Country: ru
« Reply #1784 on: February 26, 2022, 07:54:57 pm »
Yes this firmware contain all changes as in provided here beta.
Only one 'bug' i fix it today, not stable write on some SD cards (i send fixes to Hugen)
The following users thanked this post: joeqsmith
Offline tautech
« Reply #1785 on: February 26, 2022, 08:37:01 pm »
https://www.eevblog.com/forum/rf-microwave/diy-short-open-and-load-for-vna-calibration/
Out of office and unavailable for a few days.
Online nctnico
« Reply #1786 on: February 26, 2022, 11:16:14 pm »
IMHO you'd be better off buying an SMA calibrator kit from Ebay instead of making something. For starters the short is right into the connector so it doesn't add any length.
Random hit on Ebay:
https://www.ebay.com/itm/284154775104
Offline tautech
« Reply #1787 on: February 26, 2022, 11:54:08 pm »
Yes well until you've attempted to make some and compare their results against a commercially available kit how can one know.
In the thread I've linked there is a wealth of info including some good videos that align with my findings on this matter. SMA fittings are dirt cheap and coupled with SMD components and with a little care it's not hard to make Cal kit components far better that those I've checked that come supplied with any of these cheap VNA's.
Offline cdev
« Reply #1788 on: February 27, 2022, 02:45:23 am »
I found that making some other fixtures especially -a 1:1 RF transformer is useful. Still have not found a pair of very small alligator or alligator-like strong CLIPS that I am looking for, though. The transformer is to decouple whatever (practically anything) from the transmission line.
Ive never heard of most of those other VNAs. I can see how the nanovna2 is a hard act to follow.
Wonder what it takes to make a pocket sized ultrasound device like I see being sold now.
« Last Edit: February 27, 2022, 02:48:18 am by cdev »
Offline realfran
« Reply #1789 on: February 27, 2022, 09:54:57 am »
A DIY calibration kit is one waste of time for two reasons first need one professional VNA with a calibration kit to compare, second many people get some results below 3Ghz.
I think is better to find some good quality of 50homs loads and some clone of short and open (the one that came with the LiteVNA) and play with them, on the end the low-cost VNA got is on limit.
I believe one good software can better use the resources of them using PC power computation.
« Reply #1790 on: February 27, 2022, 04:32:12 pm »
Your previous referring to Kurt must have been someone who characterized a set of the included standards and not a cal kit they sell.  If that's true, I suggest you contact them and see if they would be willing to supply you with the coefficients.
Your point about needing to compare the home made set with a known setup is valid.  However, I just want to remind you that everything I have shown with the low cost VNAs has been with the included shorts, opens and load(or a hand selected load).   Or, in many cases when testing below a GHz and looking at components, a set of standards I made up on FR4 were used.   In all cases I have used the ideal model.
I could certainly attempt to characterize these standards and it may even improve my measurements some measurable amount.  However, in your case I suspect there are much bigger problems that would mask any gains.   You posted some data for an attenuator that showed several dB of error.  No cal standard can correct that problem.
Besides myself, someone else had posted a report for you making a similar measurement with their low cost VNA.
https://nanorfe.com/forum/attachments/Calibration/96e7e95e1885-0/VNA_CalCheck_Summary_12-5-2021.pdf
I would expect you to get similar results.  I've suggested you simplify your setup by removing all your home made bits until you start getting better data but I suspect you think that the calibration is going to fix it all for you.   That book I mentioned earlier is a pretty good starting point and covers a lot of basics.
https://www.google.com/books/edition/The_VNA_Applications_Handbook/_VyzDwAAQBAJ?hl=en&gbpv=1&printsec=frontcover
Offline realfran
« Reply #1791 on: February 27, 2022, 09:44:26 pm »
Yes, Kurt Pulsen has characterized a set for the liteVNA- LibraVNA and  VNWA  and many others.
The name of the software is "NanoVNA-Solver64" is good have it is a proper name  :-+
For the calibration, I use to do it first directly on the LiteVNA and after thru the HP switching test set, watching for the different results with and without the switching relay,
the isolation is 100dB and even there is some problem the LiteVNA does not see them. :-DD
« Last Edit: February 27, 2022, 10:59:42 pm by realfran »
« Reply #1792 on: February 27, 2022, 11:07:06 pm »
We kicked around a few names but Solver64 won out as it best described it.  Unlike all the previous software I have released for these low cost VNAs, version 3 is a 64-bit application.  This means a new runtime engine and VISA.
Its possible you are fighting a cable, connector, relay, attenuator ... problem.  There's just no way that an attenutor would be off by as much as you show without there being a major problem.
With the release of Dislord's firmware, I have started to work on a demonstration video for the new software.  Because of Dislords added features, the Lite will be used during the demonstration.  There's a lot to go over.  I plan to revisit the transfer relay and T-Check.   Just for you, I'll show a step attenuator.
The data that OWO had presented for the V3 showed 100dB.  They were planning to push it further.
Offline realfran
« Reply #1793 on: February 28, 2022, 01:51:42 pm »
The story of OWO OWO on the NanoVNA V3 takes time, I don't like the close source FW like the NanoVNA 2 Plus4 and the hysterical version Plus5 with some improvement (on the firmware) to scrub some money with this supposed version $329.00 and now quick disappear and recall Plus4 Pro from the Nanoforte web page.
My question is: what is the reason for Plus5 improvement? get more money? instead to upgrade Plus4  with new firmware.
One other VNA 6Ghz with (supposed 100dB) with squarewave generator for  $1300 [full two-port version] on 5-12 mont time is making noise and loss of credibility.
I hope Dislord can get another 10dB more from the LiteVNA and for the hobby, use is good.
« Last Edit: February 28, 2022, 02:12:34 pm by realfran »
« Reply #1794 on: February 28, 2022, 02:41:23 pm »
Most of my test equipment is closed source.   It doesn't concern me as long as it does what the manufacture claims.  In the case of the V2Plus4, the mail group is not public.  The last time I posted I was told to not to bring up the Lite.  I then made the choice to leave the group and have no plans to return.   We were exchanging PMs for a while but similar to what you saw her posting here a few pages back about business practices.
I assume any successful business is about monetary gains.  If they achieve 120dB that's impressive.  They claimed to support the unknown thru.  I doubt the hardware architecture is at all the same.   If they are able to get reasonable performance do to 10kHz and support narrow band measurements, I would buy one.  Even with the squarewave drive.
The Lite is very slow and can't out perform even the original NanoVNA in the lower frequencies.  Then again, I assume most of their market are CB and amateur radio operators.   I once had an electrical worker ask me why would I ever need to measure frequencies above 60Hz.    The CB/hams perspective seems to be that the VNA is an antenna analyzer.   We all have different perspectives.  OWO talked about targeting smaller companies, not the radio hobbyist.
The following users thanked this post: nctnico
« Reply #1795 on: February 28, 2022, 06:35:53 pm »
Flipper's second Lite arrived.   Sadly, same problem as his original.   Sounds like the supplied USB cable was also bad.   Measuring the voltage at the (HP Z640) USB connector at 5.098V.   There is also a rapid charge port which outputs 5.25V.  Both are too high for the LiteVNA to work properly but note that there is a difference.
Looks like the diode dropped powered hub is the fix for now.  Flipper is sending me the VNA and I will attempt to make the Changes Dislord mentioned and see if we can improve the low frequency performance.
Offline realfran
« Reply #1796 on: February 28, 2022, 07:59:42 pm »
LiteVNA64: Remove D1 R7 R1 -Please disconnect the battery and USB power connection when modifying the circuit. The battery must be connected after the modification is completed to work properly.
This is the modification suggested.
Another suggestion is: Calibrate without a USB cable (the reason is on calibration is embedded in the noise).
I calibrate the LiteVNA on battery with USB cable disconnected I started the NanoVNA-Solver V2.8 and I get this.
« Last Edit: February 28, 2022, 08:42:21 pm by realfran »
« Reply #1797 on: February 28, 2022, 08:50:55 pm »
I was referring to the front end modifications Dislord had mentioned:
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg4015222/#msg4015222
In Lite if remove DC block capacitor and ESD protection diode possible get better results on low frequency range < 10M (but this huge increase chance burn rf switch)
I have no plans to modify the power supply section.   I had asked a few questions to try and understand if these changes would cause other problems but we did not get a response.   So for now, Flipper will stay with the low voltage powered hub.
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg4030855/#msg4030855
The data I've presented in regards to the power supply noise has all been without calibration.  Calibration isn't a panacea able to overcome such hardware problems.
That said,  we always run them with a PC.  We expect raw data from the VNA and calibration is handled by the PC.  It should be easy enough to replicate.
Snip a USB cable and expose the power leads.  Power the VNA from an external supply.   Flipper's will start to act up with 5.04V applied.  I don't know the upper voltage limit before damage but it was plugged into that charge port.  Keep it below 5.2V and I suspect you are fine.
Assuming no calibration, I would expect you to measure 50-60dB in the 400kHz to 1MHz range.
Then you can try to calibrate your way out of it.  Let me know how it works out for you.
« Last Edit: February 28, 2022, 09:21:57 pm by joeqsmith »
Offline realfran
« Reply #1798 on: February 28, 2022, 09:53:09 pm »
On the PC software, I don't perform any calibration of their raw data from the VNA
« Reply #1799 on: March 01, 2022, 02:26:38 pm »
I understood that from the photo and what you had wrote.
However, you made the suggestion which suggests to me that you do not understand some of the basics.
Run through a calibration on battery (stand alone, no PC), but do not insert any of the standards when doing it.  Create a bad calibration.  Save it to 0.     Reset the unit and it should show a lot of random garbage.  Now connect it to the PC and run Solver.   If you see the same random garbage, then something is wrong!!   Again:
I had discussed this with Dislord a few pages back.  There was a time where he would not send the raw data but this was corrected:
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg3947854/#msg3947854
The data that you show is what I expect.
