Shown with a 7805 regulator, 1.84MHz oscillator, meter and various caps. The DC blocks and transformer are installed.
good job!, where can I download VI?
Thanks
I have never released the source code (VIs), only the EXEs. You will find the link to my Github account in my signature.
Make sure you read the README BEFORE you try and download and install it. One of the most common problems people ask me is they will download the EXE and then they try and find the runtime for it, then if they manage to find the right version, the software won't find the device because they still haven't installed VISA.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
The next problem is people will try and use the wrong software for their device. They have the V2Plus and are trying to use the software for the original hardware. I suspect DisLords problem with their regional settings is they didn't change their .INI file covered in the manual.
There are also cases of trying to use the software with unsupported firmware/hardware. Most likely 2.x is be be even less compatible. I suggest archiving the current versions. If you manage to get it running, the next hurdle will be reading the manual.
The PDN measurement features are still being developed. The changes will need to be added to the V2Plus and the manual needs to be updated. So it's a ways off.
