Morning,
Morning.
Explain what is meant by "normal"?
Because you didn't explain what "Step one, turn off the data while changing the frequency", I didn't do it, so ran the normal test.
You may have noticed that this was the same comment in the readme file for that release. It's not instructions for you to follow, its documenting what has been changed. More so for my own benefit. The manual now contains a Software version section that I will maintain, at least internally, to help keep track of the development.
>>>Just tried it as normal.
Ok, it's clear with your circular explanation of what normal is, you're not sure, which is normal.
Did you try both 101 and 401? Does 101 still work?
Last night only 401, but this morning tried 101 and 101 works well.
Good info.
Change the Refresh time from 200 to 600 and the PgmTimeout from 1200 to 1800 and let me know if it has any effect.
None, or at least none that I noticed. Waveform still ends up to the right of centre.
More good info.
No point in wasting too much more time with it.
Agreed.
One other thing that I forgot to mention is that all versions after 1.08 (in the SetupDiagnostics page info box), only displays 'the quick brown fox', whereas previous versions have all the nano info.
Might be something.
Certainly a possible clue. Some firmware does not report any info. If you run the terminal menu and select the info command does it send anything back?
No matter. Once the hardware arrives and you provide a link for the exact firmware you are using, I can take it from there.
In the mean time, I suggest you get a pull test jig finished so we can start to validate some of your results.
