Author Topic: NanoVNA Custom Software  (Read 539498 times)
croma641, ON7CH and 9 Guests are viewing this topic.
Offline joeqsmithTopic starter
Re: NanoVNA Custom Software
« Reply #775 on: March 15, 2021, 12:16:22 pm »
S21 log mag.  Your 6-7dBish from 500K to 25MHz is close to my jig.   What frequency range do you require?
Offline purpose
« Reply #776 on: March 15, 2021, 01:50:25 pm »
Morning,
Right now I'm not looking to go beyond 10MHz.
« Reply #777 on: March 15, 2021, 05:31:38 pm »
For your particular range, I assume that's your lower limit as well, which shouldn't be a problem.  You just want to play with your 10MHz crystals is all.
If you want to sort out the question on if your Nano supports the original command set, I would just fire up a dumb terminal program.  I use TeraTermPro but it's not important.  Select 8,N,1.  BAUD rate isn't important.   Connect to your Nano and type "help" without the quotes.    Mine will return the following: (see attached)
Offline purpose
« Reply #778 on: March 15, 2021, 06:39:18 pm »
Cheers.
Mine returns something different.
But dropping back to the previous firmware gives me this.
« Last Edit: March 15, 2021, 07:01:31 pm by purpose »
« Reply #779 on: March 15, 2021, 11:21:04 pm »
What was the reason you loaded the newer firmware?
For the original NanoVNA, my software uses the following commands:
freq
info
data
sweep (start, stop, center, span)
reset
frequencies
recall
As long as they were smart enough to keep the format the same for all of these, it may just work.
Offline purpose
« Reply #780 on: March 15, 2021, 11:28:51 pm »
Mr. Smith,
Just to see what it was all about and to see if I could do it without bricking it.
Here's hoping, but if not, I could maybe flash the same firmware that you're running.
My pcb is rev 3.4
Peter
« Reply #781 on: March 15, 2021, 11:49:25 pm »
We can cross that bridge when we come to it.   The firmware you are running may be more stable than what I have.
Once I have a little time, I will go through and functional test the new versions of software.   Hopefully, I can upload them over the weekend and make a quick video walking you through how it's done.
Offline purpose
« Reply #782 on: March 15, 2021, 11:53:25 pm »
Marvellous... Thank you.
Peter
« Reply #783 on: March 19, 2021, 01:21:55 pm »
I've been playing around with the new 1.0 software that I plan to release shortly.  While searching the forums for some decent firmware that supports the original hardware,  I kept coming across posts where people have damaged their Nanos.   One person had bought 5 of them and 3 were damaged.   This video gives some of my thoughts on how to protect the front end.   It also shows off the new software.
I finally received some much needed feedback on the manual and need to address that.  I am also seeing a small problem with the software or maybe it's firmware, that needs to be corrected.  Things are starting to come together.
Offline DrNefario
« Reply #784 on: March 19, 2021, 05:32:14 pm »
I have been using my Original NanoVNA since December 2019 now and have gone through several FW loads.  I am now on edy555's v 0.8.0 and am quite happy with it and mostly use it on the bench with NanoVNA-Saver.  This is the latest FW version from edy555 and I don't know about others, but here are the features it has:
« Reply #785 on: March 19, 2021, 08:21:21 pm »
Any known problems with it?
Offline DrNefario
« Reply #786 on: March 19, 2021, 11:45:08 pm »
In general I have not had any problems.  The github is at  https://github.com/ttrftech/NanoVNA and there is an issues list but some things seem more like a 'wish list'.
I have taken lots of data with the Nanovna-saver program including downloading S parameters and saving the cal sets.
I downloaded the binary that is listed as the latest: https://github.com/ttrftech/NanoVNA/releases/tag/0.8.0
Also, I am not a software type, but I did compile the master as listed and it did work OK, but not with the saver program.
The saver program gave me this error list when I tried to run it with my compilation:  ( it seems to not have a valid version )
Traceback (most recent call last):
  File "NanoVNASaver\NanoVNASaver.py", line 516, in serialButtonClick
  File "NanoVNASaver\NanoVNASaver.py", line 538, in connect_device
  File "NanoVNASaver\Hardware\Hardware.py", line 111, in get_VNA
  File "NanoVNASaver\Hardware\NanoVNA.py", line 40, in __init__
  File "NanoVNASaver\Hardware\VNA.py", line 61, in __init__
  File "NanoVNASaver\Hardware\VNA.py", line 186, in readVersion
IndexError: list index out of range
So, I went back to the binary v 0.8.0 which does not give any errors.
« Reply #787 on: March 20, 2021, 02:21:39 am »
Thanks for the input.  Not being able to rebuild it doesn't give me a lot of confidence but I went ahead and downloaded the image you suggested.   The first thing I notice is they did not adopt the 10KHz feature.   More useful for me than a battery indicator but oh well.   It looks like they went the other way and allow it to operate a bit over 2.1GHz.   It was pretty poor above 300MHz.  I played with the hardware above a GHz and even used it in that last review I made for the V2+4.
Its running the regression test.
What do you use the NanoVNA for?   What frequency ranges do you use?
I may have you try and run a test for me in the near future.
« Last Edit: March 20, 2021, 04:54:01 am by joeqsmith »
Offline DrNefario
« Reply #788 on: March 20, 2021, 01:22:45 pm »
I use it for various things including sweeping filters, measuring and designing impedance matching networks, component measuring and some antenna matching.  I would like to build the crystal test fixture for occasional use.  Most of this has been below 300 MHz, but I have used it for some stuff up to 1 GHz.  I have an HP3577 and an HP8753C but it is so convenient to grab the Nano and get the data into my PC that I have been mostly using the Nano.  I plan to buy one of the newer designs that would cover 4 - 6 GHz but am waiting for the designs and the shipping situation to gel.
I rarely use the built in display and would be just fine with a headless unit.  I notice that the NanoVNA-Saver application just freezes the display on the Nano, which is OK but I wonder if there would be anything to gain by blanking it when using it headless.  I realize that would require different firmware for the Nano, but this mode might be something to consider adding for the folks that are designing these new VNA's.
I would be happy to run a test for you.  deflatermaus at outlook dot com.
« Reply #789 on: March 20, 2021, 10:08:12 pm »
The 8753C is a workhorse.   There may be better software for your PC that supports it.    Your 3577 seems like it would be the unit of choice for the amateur and CB radio group.    Have you ran into cases where the 3577 provides any use to you compared with the original Nano?
I have created a new repository on Github for the old hardware and have uploaded test reports for the two versions of firmware.  One is the last version that member RadioListener posted that I had rebuilt, the other the TTRFTech binary you linked.
When you run the TTRFTech firmware, does the software you use have any sort of metrics that it provides?   Have you noticed any differences in the performance when running it with the PC?
« Reply #790 on: March 21, 2021, 05:28:01 pm »
It seems like the new firmware may have a smaller message buffer or is just using up more CPU time showing the low battery indicator.   I stack commands (send more than one) and parse the responses in a separate thread to speed things up.  This seems to cause the new firmware problems and it chokes.   You can see the effects in the two reports.   It's funny with it being as slow as it is that it has any problems.
With the firmware still being developed, supporting it seems like a problem.  Looking at the software repository is seems the original author is no longer listed as a developer.   Looks like 15 people  working on it now.   Would enjoy hearing from Rune B. Broberg on why he stopped working on it.
Peter
To make the software somewhat usable for you, I would cripple my software to work with the new firmware.  This will allow you to continue to play with the latest releases of firmware up to the point where they brake it.  At that time you would just need to archive the firmware that works the best for you.
From a software point of view, the main difference between the old and new VNAs is how the new VNA will just send the raw data and it's fairly fast.  The old required you to request both channels seperatly.   If you are only looking at S11, there's no reason to ask for the second channel.   I would leverage this to get faster updates.  Still very slow but hey, it's $50.   When using S21, I always collect both channels which doubles the time it takes to update the screen.  The advantage is the software behaves more like the V2+.    For measuring crystals, I don't see it being a problem.    If you plan to try an use it for other measurements, you may run into snags.
Offline DrNefario
« Reply #791 on: March 21, 2021, 05:54:20 pm »
Several months ago, my 3577 POST indicated an over current event by the LED's status.  There was nothing on the screen.  I traced it down to a problem with the display module and when this module is unplugged it appears to boot OK as for as the front panel indicators tell me.  I am debating weather to buy the LCD display replacement or sell as is.  So, unfortunately I can't do any comparisons with this.  I am slowly moving into a condo and really don't have room for it.
I see that you have been to:
https://github.com/NanoVNA-Saver/nanovna-saver.  I have been following the forums on groups.io for the Nano and wiki at https://groups.io/g/nanovna-users/wiki/12336.
I guess Rune thought it was useful as is and left it for posterity at github.  I'm think if you posted there he would reply as he has been quite active on the forum.
I really have not compared the stand alone performance of the Nano to it working with the Saver program, but from what I read in the forums I trust most of what it tells me.
I'll look at your reports later to see what you found.  Thank you for your work and informative videos!
Offline purpose
« Reply #792 on: March 21, 2021, 07:47:47 pm »
Mr. Smith,
Updating, or down dating the firmware takes seconds, so should you release your software I would still be game.
On another note... I've just ordered a NanoVNA H4 (bigger screen version),  because apparently there is a firmware available that gives you 401 data points. We can't have angular Smith charts.
Peter
Offline Kean
    • Kean Electronics
« Reply #793 on: March 21, 2021, 09:21:25 pm »
Peter, If you haven't already, you can check out the version he released in late January - but as Joe mentions above it is intended for the V2 Plus
https://github.com/joeqsmith/NanoVNA_V2Plus/releases/
The following users thanked this post: purpose
« Reply #794 on: March 21, 2021, 10:21:17 pm »
The V2+4 supports 401 data points running standalone and 1024 when using the PC (which is really all I care about).   It can download it at 400 data points per second.  That's everything.   When I demonstrated how to sweep in small segments, it was to overcome problems when looking at narrow band parts for SPICE.  The V2+ removes the need for it but I still have it included in the software.
Yes, I checked out their Github account today to see if I could learn anything.   I was surprised the original developer not being listed.  With 15 developers, I expect that software is very polished by now.   They adopted segmented sweeps early on and I would have expected them to roll in any other features I had shown they felt would be useful.  From reading the groups,  I didn't see a lot of people actually experimenting with RF.    So spending resources adding support for mixers, transfer relays, automated crystal characterizing may not make a lot of sense if only a few people are asking for it.   That's really IMO what people should be doing as they have a much larger support group.
I just finished editing the manual after getting some very good feedback on it and I still plan to release the software.   Running that regression test gives me some idea what needs to be done but it will require a lot more testing.    I changed my software to ease up on demands from the firmware.  It's slow but at least the data rates are stable now.
Offline purpose
« Reply #795 on: March 21, 2021, 10:33:29 pm »
Have checked it already, Mr. Kean.
Thanks
Peter
Offline purpose
« Reply #796 on: March 21, 2021, 10:50:35 pm »
Ace.
Dislord is credited in the firmware I currently run. I tried his 1.0.38 in the hope of maybe upping the data point count, but it's limited to the H4 version.
If only they could be more like you, cough.
Marvellous.
When you're good and ready, sir.
I doubt you not.
Many thanks
Peter
« Reply #797 on: March 22, 2021, 01:26:14 am »
I tried out the basic functions and checked my test loads using the new firmware.  Seems alright.   Looking in my pile of junk crystals, I had a 10MHz NYMPH that I thought I could run to give you some sort of a reference what you should see.
Beyond suggesting you not waste too much time with the EXE, my only other advice is read the manual.    Good luck.
Offline purpose
« Reply #798 on: March 22, 2021, 01:33:47 am »
The old RTFM, eh?
Well, it'll have to wait for the morning.
Many thanks, Mr. Smith.
« Reply #799 on: March 22, 2021, 03:09:58 am »
Not really.  When I see read the fucking manual, I normally end the conversation which is not my intent.   That manual is there for a reason.  Make good use of it.   If you have questions not covered by the manual, let me know and I can add more detail.  That way others benefit.  Now that the manual has been updated, I doubt I will make a clip showing how to measure crystals.
