I loaded the software onto my Windows 7 PC and it seems to work fine. This PC has an old i7 2630QM processor where the Window 10 PC uses a Xeon E5-1650 v4.
Attempting to sweep down in the 50KHz range where the worse noise is but their software appears to limit it to 100KHz.
Before digging into their source code, I tried adjusting the Ouput Power but it appears to have no effect. My guess is that it's not supported and that's why there is nothing in the documentation about how to set it.
Talking with a friend today about the USB problems with this V2P hanging. Apparently they ran into a similar problem with Windows 10 USB selective suspend causing them problems. They suggesting disabling all of the USB power saving features. I tried it and the V2P has been collecting 400 point datasets for a bit over an hour and a half now without a fault (using my software). This is the longest I have seen it run with this amount of data but I'll let it continue to run just to make sure.
It made it to two hours and I aborted the test. I restarted collecting with 800 data points. It finally hung at 2200 cycles. It collects at roughly 17 sweeps per minute with 800 points. So roughly 129 minutes until it failed.
The next attempt to run am 800 point test, the unit crashed after 210 sweeps. I tried it one last time and it made it to 4500 sweeps or around 4 hours before it crashed.
When the Nano crashed, it still shows the USB menu but doesn't respond to any USB commands. The PC still see's the port. The only way I have found to recover from it is by power cycling the Nano V2+.
After several attempts to get the VNA View (VNA QT) software to run on this PC, I did eventually get it to sweep. There isn't any way to tell how many sweeps it has ran. I'll check on it over the day and see if it has hung or not.
I ran their software for roughly seven hours and the V2P never crashed using the same PC, driver, cables, Nano. I started my software and the Nano crashed within a half hour. So it's not the USB power savings features in 10.
My software is pretty simple. When it causes the Nano to crash, it's just asking for a single data point and reading it.
