Author Topic: NanoVNA Custom Software  (Read 527048 times)
0 Members and 17 Guests are viewing this topic.
Offline joeqsmithTopic starter
Re: NanoVNA Custom Software
« Reply #325 on: September 14, 2019, 04:57:46 am »
Definition of insanity
1 dated : a severely disordered state of the mind usually occurring as a specific disorder
2 law : unsoundness of mind or lack of the ability to understand that prevents one from having the mental capacity required by law to enter into a particular relationship, status, or transaction or that releases one from criminal or civil responsibility
3a : extreme folly or unreasonableness the insanity of violence His comments were pure insanity.
b : something utterly foolish or unreasonable the insanities of modern life
Let's see, I'm looking at a $50 Chinese VNA with a $1000 phase trimmer attached to it with a $200 torque wrench.  Why?  Because a $500 stage with the $30 home made phase trimmer wouldn't let me play with some basic algorithm.
Offline Efcis
« Reply #326 on: September 14, 2019, 10:29:45 am »
Hi
If they produce the gen 2 unit that's been mentioned, I may pick one up to help quench my thirst.
It may be this one : https://www.aliexpress.com/wholesale?SearchText=nanovna-f
Rgds
Offline radiolistener
  • Country: ua
« Reply #327 on: September 14, 2019, 11:00:41 am »
this is the same NanoVNA, but pcb redesigned for large IPS display, more powerful MCU and large 5000 mAh battery.  :)
« Reply #328 on: September 14, 2019, 08:53:19 pm »
Someone was posting about a 2.4GHz version without using  harmonics and at the same cost, plus improved communications.     I've been using the Nano headless for the most part but have tried it with my 8" tablet.
I made an attempt to improve the home made delay line.  Stepping 0.01"ish  for 150 steps or  1.5"ish total travel.  Shown also is the absolute phase and distance.
Offline rhb
« Reply #329 on: September 14, 2019, 10:25:16 pm »
I'd really appreciate more construction details of your phase shifter as I intend to build at least one and possibly more.  I can resolve delays to picosecond levels on the 11801 & SD-24 combination.
I actually need 8 short (~10-20 ps maximum) phase shifters to phase match the cables from an FPGA board to my Tek 11801 w/ four 2 channel SD-26 sampling heads.  That's for measuring adder-multiplier bit skew for various DSP topologies for use in a FOSS DSO based on Zynq 7010 or 7020 FPGAs.
Making stuff like that is the justification for having a lathe and mill.  I have a Chinese 7" x 14" mini-lathe completely disassembled awaiting new bearings and scraping to make a precision toolmaker's lathe out of it.  As sold they are just a set of parts assembled at the factory to make sure they don't leave any parts out of the kit.
I'm confused by the axis labels on your displays, particularly the Y axes on the display with 3 plots.   In an earlier post you showed the sidelobes of the sinc(x) changing.  It would be helpful to know more about that data.  I spent my career doing oil industry DSP.  My instincts are that your "error" is actually exactly what you should be getting, but I need to know more about the data.
The best test of your software is to construct synthetic test cases.  For example, to test solving for the length, create  several series which are exactly exp(j*2*pi*t) for various values of t.  If t is not an integer multiple of the sample interval dT, then you'll see a sinc(x) for dT = 1/(2*Fn).  If dT is a small faction of that you will always see the sinc(x).  When it is exactly at Nyquist, the time samples all fall at the zero crossings in sinc(x).
Have Fun!
Reg
« Reply #330 on: September 14, 2019, 11:19:14 pm »
Consider the very top graph of the set of three, where I use the terms Amplitude, Distance and Length to describe the vertical axis.   This is showing the change in distance per step.  For example, looking at post 333, I an moving the stage in 0.1" increments.  The Nano is showing it from 0.101" down to 0.042".   That was using the home made phase trimmer.
Looking at post 334, where the stage is not moving, the change is +/-0.002".
Looking at post 335, where the home made trimmer was replaced with the Sage commercial part where I am adjusting it by hand, it shows between 0.224 and 0.271"
Post 336 was an attempt to do an A/B compare between the home made trimmer and the commercial part by stepping roughly the same amount.   The was between 0.174
 and 0.280".
Post 340, the stage is incremented  by 0.01" (its really 0.01000976... as it is not an even divisor).  The software reports a mean of 0.0103".  The stage moves 150 steps and show move 1.501465" compared with the reported 1.5314".   I zoomed into the side lobes to show the spacing and we can see they are not uniform.
The middle graph is just the histogram of the step sizes.  Or how many times the step size falls into a bucket.
The trimmer is brass.  Your local hobby shop should have all sorts of shapes and sizes to choose from.  There is also McMaster Carr.
Offline rhb
« Reply #331 on: September 15, 2019, 12:51:54 am »
My question about the phase trimmer was about dimensional and construction details.  The photos I looked at looked like copper pipe with SMA-F to N-F connectors at the end.  I'd expect tube on tube and tube on wire for the line.  I was wondering what the dimensions you chose were and what the measured and calculated impedances were.  What's the reflection at the SMA-F/N-F adapter to adjustable air line look like?
The vertical axes in the first PNG of #340 are "Length" ,"Score" and "Impedance".  The horizontal axes are "Samples", "Length" and "Length".  I know from inspection that the bottom figure is reflection coefficient vs time.  If you take magnitude and phase, convert to a complex series and Fourier transform you get the band limited reflection coefficient on the Y axis and the travel time on the X axis.
In the 2nd PNG of #340, "angle" only has meaning at a single frequency.  If you are comparing change in  line length and the time domain relationship that is time change, "dT".  As a consequence, I have no idea what it describes.
Your work is very interesting, but you've omitted so many details that I am unable to evaluate it.
« Reply #332 on: September 15, 2019, 01:46:57 am »
Length is inches, not time.  Peak is at roughly 20 inches.
Angle data was collected at 900MHz for each step.   Samples refers to the number of steps, which was 150 for both PNG1&2.  Trimmer moved from 19.8" to 21.3" in 150 steps.
There is no wire as you expect.  55.7 ohms, 18.2pf / 56.7nH per meter.
« Last Edit: September 15, 2019, 02:10:36 am by joeqsmith »
Offline rhb
« Reply #333 on: September 15, 2019, 03:17:52 am »
Calculated or measured?  You are either a *very*  poor communicator or  being deliberately obtuse.  I asked for physical dimensions and construction details.  You furnished *nothing* useful.
I asked a simple question about the construction of your delay line.  A linear adjustable length air dielectric delay line must of necessity have inner and outer conductors which telescope.  One *might* get acceptable results by sliding an inner conductor through an end termination, but I'm doubtful.  I'd expect significant issues with stray capacitance and inductance if you did that. You are being willfully mysterious.
Sadly, I'm forced to conclude this thread is a waste of time.  It's just joeqsmith pimping his ego.
The following users thanked this post: horo
« Reply #334 on: September 15, 2019, 02:43:19 pm »
These values were calculated based on the telescoping brass tubes that were used.
https://www.eevblog.com/forum/rf-microwave/sma-phase-adjuster-construction/msg2315619/#msg2315619
Your original post on the trimmers was from back in April and it seems you have not made any headway.
https://www.eevblog.com/forum/rf-microwave/testing-rf-connectors-and-cables/msg2640531/#msg2640531
You had mentioned having ADD and I wonder if your last comment is from your frustrations with your own personal lack of progress.
You may find the following article helpful.
https://hackaday.io/project/162998-the-rise-and-fall-of-pulses
Personally, I would have just ordered up some tubing and started trying some things out rather than lashing out at others.
Offline OA4LDR
  • Country: pe
« Reply #335 on: September 15, 2019, 09:58:16 pm »
Dear friend, I congratulate you for the work you did with that software. It makes it easier for us radio amateurs that we like to experience every day with all kinds of antennas!  In particular I like to manufacture HF and VHF antennas for me qth!  I wanted to ask you a question?  Do you have the software you made?  Or do you share it experimentally for radio amateurs?  why I wish I could have it installed on my PC!  I have the new version of NanoVNA-F 4: 3 inch screen!  Best regards from Lima Peru I leave my email to see if you can send me the software there!  oa4ldr@gmail.com a hug and greetings to all!  73s atte OA4LDR
Offline OA4LDR
  • Country: pe
« Reply #336 on: September 15, 2019, 10:00:36 pm »
Offline rhb
« Reply #337 on: September 15, 2019, 11:04:07 pm »
For which you provided *no* information.  There is not much burden in stating what size tubing you used and other basic construction details.  Not handing out software I fully understand.  Not providing the dimensions of the airline I don't.
Well, if you don't work on a project, nothing happens.  Tuesday I replaced a A/C condensor fan motor.  Friday I had to deal with replacing a 5 ton compressor and condensor and evaporator coil.  Today I investigated the linearity of the timebase interpolation of my 11801 for which the factory cal constants were lost.  If they actually existed.  In light of the results, I question whether they might not be mythical.
I have more projects than I have time left on this earth.  In most cases I also have no reason to prefer one over the other.  Things like HVAC repairs for tenants do take priority.
I had planned to write new FW for the nanoVNA today until a post on the 11801 showed up on TekScopes.  The 11801 was the smaller project, so I did that.
I did almost as well 25+ years ago without having a sampling scope and just using a generic prototype board.  Leo Bodnar does <40 ps with a BNC and less with better connectors.
Actually, I'd have started by calculating the impedances for airlines made from stock components rather than engaging in random activity.  I'd been hoping to be spared that tedium.
As you are unwilling to state the relevant dimensions, I stand by my comment.  You're a waste of time.  But..
Have Fun!
Reg
I'm out of here.
« Reply #338 on: September 16, 2019, 10:06:57 am »
Have Fun!
Reg
I'm out of here.
While I could pull apart the test setup, measure the parts, look up part numbers and suppliers and provide you with a BOM with simulation data, then reassemble the setup and get back to my projects.    Sure, maybe a half hour to sort all this out is all.    You may feel this time is not much burden on me and you deserve it but I value my time.
« Reply #339 on: September 16, 2019, 10:12:36 am »
At this time I have not released any software but check out https://groups.io/g/nanovna-users
There are a few people there making open source programs for the Nano.  I am not sure if they are an improvement over what was offered with the Nano.
  • Country: ua
« Reply #341 on: September 16, 2019, 03:34:17 pm »
After all, I done it  :-DMM
Here is TDR from S1P file that joeqsmith shared here:
« Last Edit: September 16, 2019, 03:37:41 pm by radiolistener »
« Reply #342 on: September 16, 2019, 05:56:22 pm »
Nice.  Looking at the shape of the 25ohm section,  it seems right except that the width appears to be about 2X wider than I would expect.   It looks like you show a FWHH of about 5ns where I was thinking it should be about 2.5.   The start at 14ns also seems like it's double.    Keep in mind, this could very well be a problem on my side.  If you don't find anything obvious, let me know and I will double check my work.
  • Country: ua
« Reply #343 on: September 16, 2019, 06:27:30 pm »
I tested time axis by compare with Group Delay, it shows correct time.
Here is picture with better resolution for 25 ohm section.
« Last Edit: September 16, 2019, 06:44:43 pm by radiolistener »
« Reply #344 on: September 16, 2019, 07:31:56 pm »
My guess is that you are looking at the round trip where I am trying to find the distance to the disturbance, so half that.   If that makes sense, I think we have the same numbers.  Of course, we both could be wrong.    :-DD
Offline ted572
  • Radio Communications Equipment/System Design Engr.
« Reply #345 on: September 20, 2019, 07:58:36 pm »
Please, is this the latest NanoVNA Firmware?  Kernel: 4.0.0, Build time: May  5 2019 - 08:54:38
If not, I would appreciate knowing what the latest is.
Thank you in advance for any assistance, Ted
  • Country: ua
« Reply #346 on: September 20, 2019, 08:04:04 pm »
no, this is outdated version. You can find the latest version here: https://drive.google.com/drive/folders/1IRz6E1wlkRyV0u7sbqj0lhWST-GV1szY
The following users thanked this post: ted572
Offline ted572
« Reply #347 on: September 20, 2019, 08:35:23 pm »
Thank you very much, Ted
Edit: Can you please advise which file here is for the latest NanoVNA Firmware.  I assume that it is NanoVNA_edy555_0.1.1.9.zip ???
With my firmware being dated May  5 2019 - 08:54:38, is it likely that the Hardware is the latest and/or also compactable with the current Firmware.  I'm asking because I just ordered this VNA and received it yesterday.  The first thing that I noticed is that the LEDs are Green, and NOT Blue.  So this was my motivation for checking on the current Firmware.
Thanks again for any assistance or advice, Ted
« Last Edit: September 20, 2019, 09:09:59 pm by ted572 »
  • Country: ua
« Reply #348 on: September 20, 2019, 10:18:02 pm »
There are two ways to update firmware: DFU and ST-LINK. So, it depends on what method you're want to use.
1) DFU update. This is simple but not reliable way. If something will going wrong, you may brick your NanoVNA with this method and the only way to restore it is to update firmware with the second method. DFU method doesn't requires any special hardware and you can update it just through USB.
For DFU method, you will need the file with DFU extension: nanoVNA_900_ch_20190920.dfu
In order to upload it into NanoVNA you will need DfuSe software.
You will need to power-off your NanoVNA, connect USB to PC, short BOOT jumper with tweezers and power on NanoVNA. It will be booted in DFU mode. The display will be white. Now you can release BOOT jumper and then use DfuSE Demo tool to upload firmware file into NanoVNA.
2) ST-LINK update. This is native and reliable way. But it requires ST-LINKv2 dongle. This dongle allows to flash even bricked device and also allows to use in-circuit debugging.
For ST-LINK update, you will need the file with HEX or BIN (any of these) extension:  nanoVNA_900_ch_20190920.hex
In order to upload it into NanoVNA you will need ST-LINK Utility software.
You will need to connect ST-LINK to NanoVNA with 4 wires:
- 3.3V to VDD,
- GND to GND,
- SWDIO to SWDIO,
- SWCLK to SWCLK
There is no need to solder, you can just connect wires to the pads and press it with finger during upload. Then you will need to use ST-LINK Utility tool with the following memory parameters:
- Address: 0x08000000
- Size: 0x20000
- Data Width: 8 bits
I strongly recommend to save your current firmware before update. Just in case. Both software tools allows it.
« Last Edit: September 20, 2019, 10:42:04 pm by radiolistener »
The following users thanked this post: MagicSmoker, xrunner, ted572
  • Country: ua
« Reply #349 on: September 20, 2019, 10:30:27 pm »
All existing hardware for NanoVNA is compatible with firmware. The LED color may be random, it depends on what LED color is installed by manufacturer.
For a new firmware you may need to install diode on the pcb in order to get working battery indicator. With no diode the battery indicator will always show empty battery.
« Last Edit: September 20, 2019, 10:46:13 pm by radiolistener »
The following users thanked this post: fpliuzzi, xrunner, ted572
