When running CW, why isn't the data rate faster than with swept mode? Is it throttled for a reason?
By default point measure look like this:
1 - set frequency, disconnect output, connect reference trace to ADC
2 - wait lock time
3 - measure reference (in this measure output disconnected)
4 - connect output, and connect reflect trace to ADC
5 - wait N*IF period time (N - integer, need for phase sync)
6 - measure Reflect
7 - connect thru trace to ADC
8 - wait N*IF period time (N - integer, need for phase sync)
9 - measure Thru
repeat
In CW mode step 1-4 made only for first point.
After need hope all switch for step 5-9 good phase sync, not lost any data. On device measure i can grab data and not lost sync. On usb, possible situation then buffer full, and need wait then CPU software grab data, at this moment possible lost it, and as result get wrong phase, so CW mode disabled for USB.
Anyway, at this moment i rewrite all DSP part (i add auto gain select for all measure phases), i hope this allow little faster sweep/more dynamic range in reflect measure, and solve some more problems. But need test it more.
