Same procedure, 401 data points, 1.5G to 3GHz range. I was going to try with the average set to 80 but was starting to fall asleep waiting for the thru.
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
So I set the average to 10. Because we were saving the data to the SD card, I ran the Lite off battery to give it the best chance possible.
Shown comparing the above setup (red) with the my software running the Lite the way I would normally use it (dark brown). We gain about 10dB but it does slow things down.
Also shown is the V2Plus4(tan) connected to the PC, no average and running off the PCs power. Sadly, I know using the external power degrades the performance.
Also shown is data another member had taken for the Jankae LibreVNA (black).
Feel free to repeat this little experiment and see if your results show any major improvements.
