I show the VNA without calibration for a reason. No doubt that reducing the noise in general is a good thing as long as there is no loss of information.
Because I don't tune a lot of filters, I'm not sure what people would generally consider an acceptable update rate. I would imagine instant feedback is desired but maybe once every few seconds is good enough for a few. Personally, I couldn't use something that slow to make several adjustments. Giving up data points for faster feedback is certainly something users would consider when trying to use it to tune a filter.
PS sweep speed after 6.3G decreased, need more wait generator ready.
Also, the SNR improves as we move below that. Its less of a problem.
As I mentioned, the one person who wrote was planning to average to increase the dynamic range. The one thing they never mention is what they required. It was a communications application so I would assume that they would need something better.
I was thinking I could take a filter and run it on the Lite using the firmware calibration (what ever parameters/procedure you recommend) and store the Touchstone data to the SD card. Then run it with my software. Repeat it with the V2Plus4 and maybe my old VNAs. So I pull out a SD card go to slide it into the slot and it disappears into the unit.
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
I remove the 4 screws to recover my card and then make sure I fits. No problem. I then put the case back together and try to insert the card but discover the card is too short and I need to use something to push it in deeper than the case allows to get it to lock.
The experiment was doomed before it got started.
