Author Topic: N-connector panel mount assembly, but how?  (Read 8175 times)
Offline NeganurTopic starter
« on: January 27, 2016, 11:03:53 pm »
I'm used to connectors that are either crimped or soldered and sealed. This one however, has me puzzled.
How is the shield supposed to be connected?
I'm tempted to just throw it away and get one I can crimp/solder or an N-to-SMA panel mount connector.
RF power is up to 10W.
Offline Ian.M
Re: N-connector panel mount assembly, but how?
« Reply #1 on: January 27, 2016, 11:14:35 pm »
Is the frequency low enough that you can get away with solder tags under the fixing nuts at opposite corners?
« Reply #2 on: January 27, 2016, 11:30:04 pm »
It's some 50-500 MHz and I need to cover some 3-4 cm inside the enclosure.
I think this connector is meant to be soldered directly to the PCB, so I'm probably better off looking for a different N-connector and some semi-rigid cable.
Offline TheSteve
  • Living the Dream
« Reply #3 on: January 27, 2016, 11:51:13 pm »
I would think an eyelet from one of the mounting screws to the coax braid would work.
VE7FM
Offline cdev
« Reply #4 on: January 28, 2016, 12:35:36 am »
Old school and has that big problem with grounding. **Good point.**
Online Bud
« Reply #5 on: January 28, 2016, 12:56:32 am »
Online vk6zgo
« Reply #6 on: January 28, 2016, 05:50:01 am »
There are hoods for them like this one
http://www.digikey.ca/product-detail/en/83-765/ARF1167-ND/160102
THe "N" connector is a standard panel mount unit.
The hoods aren't meant for "N" connectors,but for SO 239 connectors to attempt a match between their non-specified impedance & 50 (or maybe 75)Ohm cable.
"N" connectors are 50 Ohm by design,so the hood may make things worse,rather than better.
The normal way of making fairly critical VHF/UHF connections to panel mount "Ns" is to cut the coax to have the shortest possible centre conductor & braid pigtail,& solder the latter to the round body of the connector as close to the centre pin as you can get.
500MHz sounds hellishly high in frequency,but,remember,a wavelength at that frequency is 600mm(roughly 2 feet in the King's measurements).
The pigtail lengths are miniscule in comparison.
That said,the "N" to SMA adaptor would look much nicer!
Online Bud
« Reply #7 on: January 28, 2016, 07:10:41 am »
... to attempt a match between their non-specified impedance & 50 (or maybe 75)Ohm cable.
This does not make sense. You can only match specified impedances.
Online vk6zgo
« Reply #8 on: January 28, 2016, 09:43:50 am »
No,you can also match between measured or calculated impedances.
S0239 impedances aren't specified,but they fairly obviously have some value of impedance.
I don't know what it is!
Offline ConKbot
« Reply #9 on: January 28, 2016, 08:55:19 pm »
Those arent meant for coax. You can use solder tags and pigtails etc, but thats a hackjob. (for those firing up the keyboard with examples about what youve seen it in,no, I dont care what equipment youve seen it in or how much it cost, still a hackjob)
You'd use one of those for something where just running a piece of wire from the center pin to your PCB, and using the metal case as the ground wont cause you problems. I.e. a HF radio, where your wavelength is in the 10's of meters, a 10cm jumper isnt gonna kill you.
http://www.digikey.com/product-detail/en/082-5378-RFX/ARF1711-ND/2041837  if you want it to go to RG-58/LMR-195 etc, http://www.digikey.com/product-detail/en/172129/ACX1143-ND/1011820 for RG-174/LMR-100
Offline jimmc
« Reply #10 on: January 28, 2016, 09:10:21 pm »
'Panel' connectors are for wires, use 'Bulkhead' connectors for Coax. (see ConKbot's post)
Jim
« Reply #11 on: January 28, 2016, 11:00:55 pm »
Thanks for confirming that it's the wrong connector for what I am doing :)
Online vk6zgo
« Reply #12 on: January 29, 2016, 12:55:25 am »
I will fire up my keyboard--
Yes,it is a hackjob ---- if you have access to the nice connectors in your link,but for decades,such were the stuff of dreams for much of the Electronics Industry.
Even though it is mechanically "messy",the method I described will work at 500MHz,& has been used with coax for many years.
Obviously,the connectors you linked to are a neater & more secure way of doing the job,but blanket statements like yours can cause a lot of confusion amongst less experienced members.
Offline AF6LJ
« Reply #13 on: January 29, 2016, 01:07:09 am »
Jim
That's the way to do it.
Open up any higher end piece of RF test equipment and you will see those connectors.
sometimes they are SMA or K connector on one side N on the other.
Sue AF6LJ
Offline _Andrew_
« Reply #14 on: January 29, 2016, 01:11:08 am »
Offline AF6LJ
« Reply #15 on: January 29, 2016, 01:29:37 am »
You might want something like this ...
http://centricrf.com/adapters/n/n-to-n-bulkhead-flange/
Or ...
http://www.amphenolrf.com/242125.html
This is more like what is seen in the kind of test gear I have seen / owned / worked on.
Sue AF6LJ
Offline SNGLinks
« Reply #16 on: January 30, 2016, 11:13:08 am »
This is an investigation into the impedance of SO239/PL259 connectors.
http://www.qsl.net/vk3jeg/pl259tst.html
I think of them not as RF connectors but screened banana plugs!
Offline Kalvin
  • Embedded SW/HW.
« Reply #17 on: January 30, 2016, 12:34:14 pm »
Something like these?
N to SMA:
http://i.ebayimg.com/images/g/6XIAAOxyIAZRrBSD/s-l1600.jpg
N to BNC:
http://i.ebayimg.com/images/g/Xu0AAMXQWlFRrBTg/s-l1600.jpg
There seems to be also N-type panel mount connectors with different kinds of pigtails.
Offline AF6LJ
« Reply #18 on: January 30, 2016, 01:44:37 pm »
There is a lick of information in that study.
What brand of connectors were used?
Insulating material?
Methods used to interface them to a cable, and cable type used?
Let me also point out that in the real world an acceptable return loss for a mobile radio installation is ten DB. (2:1 VSWR more or less.)
I have to call Bullshit on this study simply because of the gross omissions in important information.
By the way..
Based on my own tests using quality connectors and cable I have seen much better results using PL-259 / SO-239 combination.
Would I use them in RF test equipment?
No
Apples and oranges comparison...
Sue AF6LJ
Offline cdev
« Reply #19 on: January 30, 2016, 04:08:00 pm »
There is a long kind of SMA that both grabs a PCB at its edge for soldering there and also lets one get a positive electrical connection on a metal case where the SMA passes through it.  They are the SMAs that look abnormally long which bundle a pair of hex nuts and a lock washer with them.
*Most* N's are 50 ohm connectors.  They are thought of as 50 ohms.
