Author Topic: Multiband WSPR on the cheap  (Read 2107 times)
Offline rhbTopic starter
« on: April 19, 2019, 02:38:26 am »
This is sort of crazy, but WB9LVI implemented a multiband WSPR transmitter using a FeelTech FY6600.  Here's a link to the QEX article.
http://www.arrl.org/files/file/QEX_Next_Issue/May-June2019/Steber.pdf
While I despise F***Tech because of their lack of customer support, it's actually a good device and the FY6800 incorporates many improvements developed by forum members in this thread:
https://www.eevblog.com/forum/testgear/feeltech-fy6600-60mhz-2-ch-vco-function-arbitrary-waveform-signal-generator/
So far as I know there is no documentation of the RS-232 interface, but it is there and with a GPSDO to time the transmissions it would neatly cycle through all the band allocations using a PC or any cheap MCU.  So it has the potential to be a very valuable tool for investigating propagation up to 6 meters.  At low power levels (1-2 Vpp output) the spurs are comparable to my Keysight 33622A  without the benefit of the output amp modification.
The following users thanked this post: I wanted a rude username
Offline Johncanfield
Re: Multiband WSPR on the cheap
« Reply #1 on: April 19, 2019, 09:15:43 pm »
Check out QRP Labs, I have built three of his U3S kits. I have one on the air now reporting to WSPR - 30 meters.
Offline Lord of nothing
  • Country: at
« Reply #2 on: April 22, 2019, 02:01:52 pm »
 :palm:
30 meters
Not very far.
Made in Japan, destroyed in Sulz im Wienerwald.
The following users thanked this post: Kalvin
« Reply #3 on: April 22, 2019, 04:29:44 pm »
:palm:
30 meters
Not very far.
Rather obviously not a radio guy
