Hi RF gurus,
I have just got my first VNA, and I'm looking for doing some tests with it.
I'm mainly interested in inductance/capacitance measurement and EMI chamber/antenna calibration (actual high sensitivity EMI measurements will be done with an SA).
My VNA came with 3.5mm female connectors, and I'm supposed to mate with a 2.92mm or 3.5mm male connector.
However, those cables are not cheap, and mostly only come in conformable or semi-rigid. I was not able to find a <$100 flexible cable assembly.
So my question is, what kind of damage and performance degradation am I looking at if I rape the connector with standard SMA cables?
My intended frequency is <6.5GHz (VNA limit).
Thanks.
