Loading [MathJax]/extensions/Safe.js
Author Topic: Signal improvement using a ferrite rod with a small loop antenna  (Read 1022 times)
Offline prabhatkarpe4Topic starter
  • Country: in
« on: September 30, 2024, 11:49:26 am »
I have used my small loop antenna (which has a main loop and a coupling loop that can be tuned using a variable capacitor) with an AM radio receiver to receive MW broadcasts. However, the small loop antenna which was made by me was not working properly but when I connected a ferrite rod loop (which has two windings on it---one with 60 turns and the other with 30), I saw a great improvement in radio reception. I connected the 60 turns loop with the main loop of the small loop antenna and the 30 turns loop with the AM radio.
The ferrite loop is not working as an antenna and when I turned it, I didn't get any difference in signal strength. However, when I turned the small loop antenna, I saw the change in signal.
So, I need to know why this has happened and did the ferrite rod work like a balun?
I have attached the diagram of the setup.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Signal improvement using a ferrite rod with a small loop antenna
« Reply #1 on: September 30, 2024, 04:55:06 pm »
I'm afraid, explaining why, would require RF knowledge --
https://www.eevblog.com/forum/rf-microwave/number-of-turns-for-the-coupling-loop/msg5657791/#msg5657791
Should I take that to understand, you are interested now in deepening your knowledge?
Seven Transistor Labs, LLC
Online radiolistener
  • Country: Earth
« Reply #2 on: September 30, 2024, 04:59:52 pm »
in your case it works like transformer with impedance transform ratio 4:1. And yes, such transformer can be used as balun.
  • Country: in
« Reply #3 on: October 01, 2024, 11:54:53 am »
But howcome that's 4:1? it's have 60/30 turns and should be 2:1.
Offline ftg
    • ftg's RF hax paeg
« Reply #4 on: October 01, 2024, 11:58:43 am »
Impedance transformation ratio is the square of the turns ratio.
2^2 is 4, thus 4:1 impedance transformation ratio.
Offline A.Z.
  • if you can't measure it, you can't improve it
    • QRPer forum
« Reply #5 on: October 02, 2024, 03:25:00 pm »
Yep, we have 60 and 30 turns, so the turns ratio (not the number of turns) is 2:1 which means a 4:1 impedance transformation ratio, as a note it's usually a good idea to wind the lowest reasonable amount of turns (depending from core material characteristics) to reduce losses and avoid unwanted self-resonance, an example, willing to wind a 9:1 transformer using a #73 binocular core we start by obtaining the turns ratio, that is sqrt(9), which gives us 3, at that point we wind 6 turns and 2 turns which will result in our 9:1 impedance ratio corresponding to the 3:1 turns ratio we calculated
