Soldering the edge joints of a woven metal mesh doesn't prevent bad contact between crossing wires in the weave, hence my comments above. I *really* wouldn't fancy trying to get a solder joint on every wire crossing in a fairly fine weave mesh - as, assuming a 3mm wire pitch, that's close to 4500 crossings to solder in a 20 cm square 'window'!
