I tried to play with ADF4351, tune it to wifi channel and connected output to wifi antenna, but wifi still works
It stops to work when I put generator antenna close to tablet and make a little frequency offset, at some offset it stops to work, but it still able to receive other wifi channels. I tried to do frequency sweep to cover entire channel bandwidth 50-1000 times per second, but it don't works, wifi works ok.
ADF4351 has about 0 dBm output (0.001 Watt), I believe it can works better with 2-4 Watts power amplifier, it can just overload nearby wifi receivers, but it requires precise tuning on specific frequency. With using circuit posted on first topic starter post it is almost impossible.
There are at least two issues with topic starter circuit:
1) no way to tune at specific frequency of wifi channel
2) too small output power
And it seems that constant carrier is not reliable way to jam wifi channel, there is needs for a more smart patterns.
And there are at least two common WiFi bands - 2.4 GHz and 5 GHz. So, even if you jam 2.4 GHz, 5 GHz still can work...
