Greetings,
Looking for datasheet for a RF detector, HEROTEK DT1812-121, p/n 01-004916-00.
It is supposed to be a negative out RF detector diode with a frequency range 12-18 GHz.
It has been verified to work in a much wider frequency range and also with a good RL.
No data has been found on the internet. The design is SMA (male) for RF input and SMA (female) for DC
output. Length is 62mm and diameter 8mm. Judging from a gap in the label, this is
a "multi-stage" design, possibly consisting of an integrated attenuator in front of
the diode assembly itself.
Cheers
Ulf K
