Loading [MathJax]/extensions/Safe.js
Author Topic: LNA spf5189z issue  (Read 20882 times)
Offline radiolistenerTopic starter
  • Country: Earth
LNA spf5189z issue
« on: July 10, 2019, 01:11:51 am »
I just got LNA module from aliexpress, it is based on spf5189z chip.
It worked great, but not for long. It is died in several hours. Now it has short circuit on the output pin. And I don't understand the reason for that.
I powered it from lab power supply with 5.01 V with 0.2 A current limit settings.
It was connected to antenna through decoupling capacitor and over-voltage protection diodes (1N4148).
Output was connected to RTLSDRv3.
All equipment (PSU and PC) is grounded, include ground contact of the antenna.
I connected antenna output to BM867 in CREST mode, just to make sure that there is no high voltage pulses. It worked for a several hours and largest catched pulse is just 0.479 V.
See picture of PCB in attachment. Also I added schematic that I reversed from PCB.
Before use I replaced R1 (jumper 0 ohm) with ferrite bead (BLM18EG601 - 600Ω @ 100 MHz / 0.35Ω @ DC).
It worked well for several tests and it's current consumption was 0.07 A.
But after next power on, I noticed that current is jumping up to 200 mA (limited by power supply).
And that's it, after that it doesn't works :(
I also found this article related to the subject: http://pa0o-jaap.blogspot.com/2018/04/spf5189z-lna.html
But it's not clear what is the reason for burnout and how to avoid it?
Any idea why it happens?
« Last Edit: July 10, 2019, 02:51:54 am by radiolistener »
  • Country: Earth
Re: LNA spf5189z issue
« Reply #1 on: July 14, 2019, 03:55:36 pm »
I have idea that it is burned out just because it may start self-oscillating, when input is open and it leads to high current consumption. Since there is missing current limiting resistor, it consumed too high current and is burned out. It seems that my power supply limit 200 mA is too high for spf5189z.
Does this theory possible? How to protect it from such conditions?
I'm thinking about add 30-50 Ohm resistor for power line. Would it work?
Offline biastee
  • Country: my
    • 9W2LC
« Reply #2 on: July 15, 2019, 08:21:26 am »
I would not place oscillation at the top of a list of suspects because:
1. if an amp oscillates, the output is ~P1dB; i.e. below the abs max rating.
2. MMIC amps have a long history of being pressed into service as oscillators without problem.
785610-0
Another example of MMIC amp used as oscillators
Did u switch off the power supply and then switch it on again? Turn on transients are known to be very damaging.
see pg 3 of this
« Last Edit: July 15, 2019, 08:25:16 am by biastee »
The following users thanked this post: radiolistener
  • Country: Earth
« Reply #3 on: July 15, 2019, 11:17:22 am »
see pg 3 of this
yes, it happens when I switch off and switch on several times in a row.
It was not power switch, I just touched wire with alligator clip connected to lab power supply.
And I used long wires (about 1.5 meters) to provide power for the module.
How to fix it? If I add 68 uF capacitor on amplifier PCB (after ferrite bead), does it helps to solve it?
What is the safe schematic for power supply filter on LNA module? (for spf5189z).
Originally I got it with just two capacitors and 0-ohm jumpers instead of resistors.
Before damage, I replaced R1 with ferrite bead (BLM18EG601 - 600Ω @ 100 MHz / 0.35Ω @ DC).
This LNA module has very nice aluminium shield. But it seems that it needs for some modification on power line.
What modification can you advise me to improve protection for power on/power off conditions?
« Last Edit: July 15, 2019, 11:53:55 am by radiolistener »
Offline biastee
  • Country: my
    • 9W2LC
« Reply #4 on: July 15, 2019, 01:48:17 pm »
1. Ya, adding the uF-range cap should help.
2. Twist together the 1.5m long wires to reduce the parasitic inductance
« Last Edit: July 15, 2019, 01:52:44 pm by biastee »
Offline Alexei.Polkhanov
« Reply #5 on: July 16, 2019, 10:58:02 pm »
Any change you powered it up in reverse by accident? If it takes 200mA then this current is going somewhere so something must be hot. I would just replace SPF5189 by a new one - they are $6 from Digikey and places alike.
Did you measure it with 50ohm terminator(s) screwed on to the input and output?
L1 is meant to block RF from coming back but also should block some of the transient currents on turn on.
  • Country: Earth
« Reply #6 on: July 17, 2019, 04:45:48 am »
no, the ground wire was always connected during series of measurements. I don't think that random reverse polarity was possible in such configuration.
But I connected power supply with wire touch, so there is possible series of short pulses on power line at connection time.
No, there is nothing hot, may be because the chip has good thermal contact with aluminium shield. The voltage dropped down to < 1 V due to OC stabilization.
I tested it with multimeter, it shows 17.02 Ohm on the spf5189 input pin and 6.29 Ohm output pin. When it worked well it was about 1 MOhm on both.
So, it seems that short circuit happens at the output pin of spf5189.
The input connector was opened when it happens. The output connector was connected to RTLSDRv3. But I'm not sure that it happens at power on. Before that input was connected to antenna.
Previously I applied power when input and output was open, power consumption was 0.07 A and it worked well after that. I tried it several times and after that it worked well.
I suspect that L1 may lead to overvoltage when power on condition is not clean and has series of short pulses. Or may be static electricity applied on power pin of the module. Is it possible?
Here is my gain measurements for different power supply voltages - 0V, 3.21V and 5.02V which I performed before incident (input level is -40 dBm):
« Last Edit: July 17, 2019, 06:24:03 am by radiolistener »
Offline tombi
« Reply #7 on: July 17, 2019, 03:56:16 pm »
I had one of these from Banggood but it wasn’t in a nice block but just had a little can over the chip.
It died pretty fast too and I bought some cheap replacement MMICs from China.
My theory was that I was accidentally shorting the power alligator clip to the can and it was earthing some other way (and thus reverse biasing it). Soldering leads to the PCB seemed to prevent further deaths of amplifiers but to be honest I stopped playing with it shortly after.
Tom
Sent from my iPhone using Tapatalk
Offline Bud
« Reply #8 on: July 20, 2019, 09:37:33 pm »
Try powering the amp with 9v via a 50 Ohm current limiting resistor. You can use two 100 Ohm resistors soldered instead of R2 and R3 in parallel. Use 0805 or better 1206 resistors if they fit. This way your amp will see 50 Ohm load at low frequencies, as oppose to being RF  short circuited. Pads for  R2 and  R3 were placed there  for that type of current limiting  in the first place.
  • Country: Earth
« Reply #9 on: July 20, 2019, 10:56:16 pm »
spf5189z has the following Absolute Maximum Rating according to datasheet:
Max Device Current: 120 mA
Max Device Voltage: 5.5 V
So, I don't think that powering it from 9V is a good idea  :)
Currently I don't have replacement, waiting for a shipment...
Offline Bud
« Reply #10 on: July 20, 2019, 11:13:19 pm »
Per the device datasheet, the current through the device is 90mA @5V. With a 50 Ohm series resistor the voltage drop across the resistor will be 0.09*50=4.5V. With a 9V power supply the voltage across the device will be 9-4.5=4.5v
You measured 70mA current @5V , which is by the way already outside of the  datasheet spec, which may indicate you got a fake. Anyways, lets say you have 70mA, then the voltage drop across the 50 OHM series resistor will be 0.07*50=3.5V. With a 9V power supply the voltage across the device will be 9-3.5=5.5V which is within the device spec per your note above.
Offline Bud
« Reply #11 on: July 20, 2019, 11:50:24 pm »
If you have a concern on overvoltaging the device, do as i said but power the circuit from a variable power supply and monitor the DC voltage across the amplifier. Increase the power supply voltage until you reach 5V across the amp, and you will see the supply voltage will be around 9V.
  • Country: Earth
« Reply #12 on: July 21, 2019, 03:07:30 pm »
I think there is no guarantee that spf5189 resistance will be constant at power on transition. So, at 9V and 50 Ohm limiting resistor it may apply up to 9/50 = 180 mA current. It exceeds absolute maximum rating, which is max 120 mA.
But idea to use current limiting resistor is good. Since it works with almost the same gain from 3.2 V, a small resistor should not make big difference, but may protect MMIC from over-current.
Offline biastee
  • Country: my
    • 9W2LC
« Reply #13 on: July 22, 2019, 06:11:39 am »
As long as you avoid connecting the power supply with a wire touch, the problem should not recur. Making the same connection via the power supply's ON/OFF switch is safe because the voltage will ramp up gradually on a good lab supply. However, if you really want make the LNA bulletproof, then u will need to install a transient-voltage-suppression (TVS) diode (transil) close to the device.
  • Country: Earth
« Reply #14 on: July 22, 2019, 09:38:37 am »
Can I replace TVS diode with some small 5 V linear regulator installed within LNA shield?
For example - L78L05, it has 100 mA limit, probably it also may be used as current limiter, is it correct?
« Last Edit: July 22, 2019, 09:58:17 am by radiolistener »
Offline biastee
  • Country: my
    • 9W2LC
« Reply #15 on: July 22, 2019, 01:42:56 pm »
Yes
  • Country: Earth
« Reply #16 on: August 31, 2019, 01:42:04 pm »
Some update. I got these spf5189z from aliexpress: https://www.aliexpress.com/item/33026418359.html
They come in tape reel package from cheap and dirty plastic which has noticeable quality difference from original tape reel package components. Also it has weak marking which is different from original one.
I replaced old burned spf5189 with a new one. But it turns that this is fake  :horse:
It works, but it's power consumption is 145 mA and gain below 100 MHz is 10 dB lower than original spf5189. It heating like hell, so the aluminium shell is pretty hot while powered. Also it has different frequency response than original one, fake spf5189z has a gap with gain 0 dB at 13.5 MHz (see picture). Original one don't have such gap on a frequency response.
I left it powered on for a night (for test) and at morning I found that it also burned out. I'm not sure if it was burned due to high current or some high signal from antenna (antenna input has DC block capacitor and voltage limiter with two 1N4148). But anyway this fake much worse than original one and has high current consumption which is out of specification.
I also found that fake spf5189 has about 3 kOhm on the input pin (I tested it with Brymen BM867 before soldering). As I remember, original one has about 1 MOhm (I tested it while it was ok). But I'm not sure, since original is burned out, so I cannot measure it now.
When burned out, fake spf5189z has about 2 Ohms on the input pin, the same as original.
If someone have original spf5189z, it will be interesting to know it's input resistance (measured for DC).
« Last Edit: August 31, 2019, 01:58:30 pm by radiolistener »
  • Country: Earth
« Reply #17 on: September 14, 2019, 09:04:55 am »
I want to modify original circuit for bias tee.
What is the best way to modify this circuit to provide power through bias tee?
I cannot get a new PCB, so I need to reuse this one:
« Last Edit: September 14, 2019, 09:08:56 am by radiolistener »
Offline biastee
  • Country: my
    • 9W2LC
« Reply #18 on: September 14, 2019, 12:31:10 pm »
That depends on whether you want to supply it with 5V as originally, or you want to use a higher voltage such as 12V. In the 1st situation, just replace C4 with a 0R jumper. In the second situation, solder a chip resistor on top of C4 to provide the required voltage drop.
835218-0
« Last Edit: September 14, 2019, 12:35:54 pm by biastee »
  • Country: Earth
« Reply #19 on: September 14, 2019, 04:24:37 pm »
biastee, thanks, looks pretty easy :)
But... Is it safe for MMIC to power it directly from long coax line?
« Last Edit: September 14, 2019, 04:27:29 pm by radiolistener »
Offline biastee
  • Country: my
    • 9W2LC
« Reply #20 on: September 15, 2019, 03:19:37 am »
i m not aware of any problem  8)
Offline desolatordan
« Reply #21 on: September 21, 2019, 09:15:12 pm »
If you are powering up the power supply, THEN connecting power to the amplifier, you are likely causing an over-voltage condition that's killing it.  The input inductance (including any length of coax) will resonate with input capacitance.
  • Country: Earth
« Reply #22 on: September 22, 2019, 07:49:17 am »
I suspect that the root of cause why it was burned out, is not a power. Probably it's just Chinese quality or strong signal from antenna. I tried to power on/off another module a lot of times and it still works ok.
I'm using two inverse-parallel 1N4148 diodes for over-voltage protection on the input of LNA module. But may be these 1N4148 are not fast enough.
Regarding to the bias-tee power mode, I still not sure if direct power from coax line is safe. I didn't tested it yet, I bought bias-tee module, but still waiting for it... :)
Offline OH2LIY
« Reply #23 on: December 12, 2020, 07:00:39 pm »
Hi, I recently buyed these: https://www.ebay.com/itm/254599063723?ViewItem=&item=254599063723 .
From the beginning, I was sceptical what I get. Easiest thing is measure voltage/current. Datasheet says ~90mA@5V. These crappy chinese mmic what I got, takes over 150mA@3V (limited by power supply current protection, 3V measured from mmic output).
Real thing is measure noise figure/gain, and it`s way over what it should be.
I can say directly that these are Crappy Fake Relabelled  MMICs, and ebay refunded instantly after opening counterfeit case.
  • Country: Earth
« Reply #24 on: December 13, 2020, 06:50:14 am »
My one is the same 150 mA and the same marking. I think this is remarked other type of MMIC.
May be TQP3M9009 or something like that.
« Last Edit: December 13, 2020, 06:52:09 am by radiolistener »
