This has been done before, but I'm going to document it here on this forum with some additional pics. My friend has two Kenwood TS-2000s and they both have back light problems. I'm replacing the bulbs with LEDs on both of them.
I removed the radio top and bottom covers, all knobs on the front, the nut holding the friction assembly of the knob, four side screws that hold the front panel on, and unclipped the plastic tabs and removed the plastic front. Also remove two connectors and a white ribbon cable to get the front electronics assembly off. Then take off the four screws holding the display board and remove the white ribbon cable going to that.
The original backlights are 5.5v bulbs - six total, with three pairs, each pair wired in series - see attached schematic snippet. The lamps are driven by a dimming circuit with four levels. Obviously if one lamp fails in each pair that pair will not light at all. This radio had no lights working. I unsoldered all the bulbs and found that five of the six were bad.
Tomorrow I need to remove three 5.6 ohm SMD resistors and replace with 150 ohm 0.25 W resistors for the proper current drive to the LEDs. The 3mm LEDs are on order and will be here shortly. The person is slightly colorblind and we looked at some different colors of LEDs lit up, but in the end he decided to go with something that matched the original looking color (as I see it) which is an amber/yellowish tint even though it doesn't look like that to him, in case he ever wants to sell them.
That's it for today.
