Hello,
New to the forum and have this problem;
I am using this kind of radio modules with an on-board RF stage, activated with a PAC pin;
https://www.aliexpress.com/item/CC1101-CC110L-wireless-module-medium-power-600-800-meters/1576224501.htmlhttp://www.electrodragon.com/product/cc1101-433m-wireless-module-variable-designs/Using one of them in my cold (corrugated sheet metal) garage to measure temp/humidity/groundtemp and controlling a block heater relay.
After around a year, they start losing range, first one lasted almost two years and now I had one last 1.5 years. Would not contact indoor unit with garage door closed. Replaced module and it works.
Module is in an enclosure but antenna sticking out, sealed as good as possible with Blu-tak and hot glue. For the new node I will 3D print an enclosure that fits both module and antenna, in clear PLA for best RF performance.
I sometimes suspected the SMA antenna connector, cleaned multiple times and sometimes that helped but on this latest module I had the antenna soldered so that is not a cause.
Could it be humidity creeping into caps/resistors and then cracking them in subzero temperature?
Sometimes I suspect the AS169 RF switches that direct the signal to/from RF stage.
Could it be salt depositing on the board? I live 500meters from the Gulf of Bothnia and 200meters from a salted motorway. Tried cleaning the modules with distilled water and propanole to no help.
And to add, it is controlled by an Atmega328, Arduino and PanStamp driver,
https://github.com/raimue/arduino/blob/master/libraries/panstamp/cc1101.cpp .
I have a similar module indoors that lasted many years.
Also have a CC110x module without RF stage in my basement storage and that is able to send even if the garage node is acting up so it is not the indoor base station module having problems.
