Author Topic: stripping tool for UT141 hardline?  (Read 1306 times)
Offline paul@yahrprobert.comTopic starter
« on: May 18, 2022, 07:22:57 pm »
Anybody know where to get a reasonably priced hand tool for cleanly stripping the solid outer copper jacket on UT141 hardline or semi-rigid coax? Or do you have a trick method using conventional tools?  Thanks!
Online Grandchuck
« Last Edit: May 18, 2022, 07:43:04 pm by Grandchuck »
Re: stripping tool for UT141 hardline?
« Reply #2 on: May 18, 2022, 07:53:14 pm »
the tubing cutters I've tried tend to reduce the ID a little at the cut, leaving a sharp burr pointing towards the center conductor.  Probably also creating an impedance bump.
Offline coppercone2
« Reply #3 on: May 18, 2022, 08:49:57 pm »
the proper kit has a expensive tool for this but I forgot what its called
Online themadhippy
« Reply #4 on: May 18, 2022, 09:42:43 pm »
If its anything like mineral insulated cable
https://youtu.be/IujQEj8hQoc?t=949
you can knock up a "key" with a length of rod,  cut slot cut in one end and bend the other into a handle.
« Reply #5 on: May 24, 2022, 05:39:43 pm »
I didn't find anything to strip my coax, so I made a fixture for my dremel tool.  See pictures.  I used the plastic routing attachment that came with the tool and screwed on an aluminum assembly that supports the coax as I twist it.  Also shown is the resulting stripped coax.  It needs a little deburring with a needle file, but the result is pretty good.  It takes a few practice cuts to get the depth set right.
Pro tip: don't bend your coax before stripping it.
The following users thanked this post: RoV
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #6 on: May 30, 2022, 02:50:19 am »
The ones I have seen used at work just look like miniature tubing cutters.   The bender looks like a miniature conduit bender.
Offline coppercone2
« Reply #7 on: May 30, 2022, 03:28:00 am »
I think what i saw was a metal jig with a carbide scribe that you rotate around the pipe, not a wheel. like a lathe cut.
