Mystery boards from L3 CommunicationsKenton (Evilmonkeyz) and I swapped some duplicate scrap a while back, and so I ended up with these mystery modules. Based on the construction style and part numbering, they look like they were originally part of some kind of aerospace or military radio system made by L3 Communications (CAGE code 06401, which shows up everywhere on these).
![](https://live.staticflickr.com/65535/53716378670_c2f6b8429c.jpg)
![](https://live.staticflickr.com/65535/53716285304_fe6733af80.jpg)
![](https://live.staticflickr.com/65535/53715033657_5b43a995bb.jpg)
![](https://live.staticflickr.com/65535/53715950871_c14c11d665.jpg)
The many wires and coax cables branching off each of these boards, along with their irregular shapes and small size, suggests that each one lived in its own shielded compartment separate from the others. Would've loved to see what the whole system looked like intact before it got taken apart and the pieces ended up on eBay.
Amp and filter boardLet's get the simplest one out of the way first.
![](https://live.staticflickr.com/65535/53716284804_8332d20caa.jpg)
![](https://live.staticflickr.com/65535/53715945426_fba0d179b5.jpg)
This looks like just a couple amplifiers (one of which is missing), followed by a filter module. The filter helpfully lists its frequency (12 Ghz) and manufacturer (12855 = Smiths Interconnect). The "wj" on the amplifier module suggests it's made by Watkins-Johnson, a big radio manufacturer:
![](https://live.staticflickr.com/65535/53716284774_96ba9bc3b1.jpg)
There's also a directional coupler on the output for sampling the output signal and bringing it off-board somewhere. The very non-coaxial-looking wire connection exiting at the top-right (very much not appropriate for a 12 Ghz signal) suggests that the 2-terminal gold device there is some kind of power sensor - this could be just as simple as a fast diode and a capacitor. It's also interesting to see the "pass-through" ceramic block in the lower-left, where maybe an attenuator would've been placed in a different design variant.
PLL board![](https://live.staticflickr.com/65535/53716285304_fe6733af80.jpg)
![](https://live.staticflickr.com/65535/53716285454_e737810290.jpg)
The main feature of this board is the Qualcomm Q3036M, which is a mil-spec version of the Q3036 PLL controller. I couldn't find a datasheet for this chip directly, but there's one for the slightly upgraded version, the Q3236, which mentions being backwards-compatible with the Q3036:
https://www.qsl.net/n9zia/omnitracs/q3236.pdf![](https://live.staticflickr.com/65535/53715946286_4e7f8dab1e.jpg)
This contains everything for a frequency synthesizer except the VCO (for flexibility), and the actual analog portion of the control loop, between the frequency/phase-detector output and the VCO input. This second part seems to be provided by the Philips 5534A op-amp next to it.
You can see a bunch of slightly-unusual passives:
![](https://live.staticflickr.com/65535/53715033567_5f0b5c5194.jpg)
![](https://live.staticflickr.com/65535/53716285704_ffbd4a4e6a.jpg)
...and a couple metal cans on the bottom:
![](https://live.staticflickr.com/65535/53716379735_51e10d80cd.jpg)
Wasn't able to find data on either of these, but my guess is that one of them is a stable oscillator that provides the reference for the frequency synthesizer. I may saw them open soon to have a look inside.
(Edit: the smaller can is an
LM126 dual-tracking voltage regulator, probably used to generate bipolar analog supplies for the PLL circuitry. The larger one looks like the reference oscillator - I sawed off the lid but was immediately greeted by a foam filling...no easy decap here)
VCO board #1![](https://live.staticflickr.com/65535/53715033657_5b43a995bb.jpg)
![](https://live.staticflickr.com/65535/53716156758_bbe998efaf.jpg)
The board is extremely simple, with just a closed VCO module, and a pass-through trace for something unrelated. The module here is listed as a "SAW Oscillator" with an 862.15-862.85 Mhz tuning range at
this semi-sketchy parts sourcing website.
![](https://live.staticflickr.com/65535/53715036102_33c6c7b4d2.jpg)
![](https://live.staticflickr.com/65535/53716382605_39fc7144d1.jpg)
Let's open it up and have a look inside:
![](https://live.staticflickr.com/65535/53715036272_1e8ca7c491_c.jpg)
![](https://live.staticflickr.com/65535/53716288669_a6b57d70bc_c.jpg)
![](https://www.eevblog.com/forum/rf-microwave/interesting-unusual-rfmicrowave-boards/?action=dlattach;attach=2194351;image)
![](https://www.eevblog.com/forum/rf-microwave/interesting-unusual-rfmicrowave-boards/?action=dlattach;attach=2194357;image)
You can see the rough arrangement from the schematic: there's an amplifier with a frequency-dependent feedback loop, forming the oscillator. The oscillator's output gets split off and also goes through a separate amplifier to buffer the output signal, followed by a bandpass filter to clean up any harmonics.
The main source of phase shift (and therefore what mostly determines the oscillator frequency) in the feedback path is the SAW filter, in the gold can. SAW stands for
"Surface Acoustic Wave" (SAW); it's essentially a mechanical delay line but which can propagate even multi-Ghz signals along the surface of piezoelectric material, transmitting at one end and receiving at the other. The delay is set by the distance between the transmitter & receiver, and the propagation velocity, so it's known for being stable with temperature, and if I remember correctly, being more resistant to vibration and shock than a quartz crystal oscillator. I'm not an expert on these, though, and they're an entire rabbit hole of physics on their own.
The same structure with two coupled inductors pops up a lot in this circuit: I haven't gone deep enough into the RF world that I recognize all the common circuits off the top of my head, but it sure looks like a lumped-element transmission line at a specific frequency. A couple articles (
1 and
2) explicitly call out this circuit as a lumped-element version of a coupled-line coupler, which makes sense from looking at it. This is used as a power splitter on the output of the oscillator, to send half the power back through the feedback network, and half to the output-buffer amplifier. However, I don't understand the use of this coupler in its two occurrences in the feedback network. My best guess is that it's doing something like generating 180°-separated signals to feed to the tuning varactors, and then recombining them, to cancel out any asymmetries generated by the non-linearity of the varactors - haven't worked through the math though.
In the output filter, the tiny sections of wire across the capacitors to ground are used as inductors: this makes sense when you look at the values. For a parallel LC circuit to resonate at 862 Mhz (and therefore allow the fundamental output frequency to pass, while shorting others to ground), 15 pF → 2.3 nH. (It's convenient that these RF caps have the values written on them) 2.3 nH is a very plausible value for that short loop of wire.
I'm not sure what type of transistors are used here, as strangely there's no DC biasing on their inputs. They might have some kind of output-to-input biasing resistance added internally, or they could be something like JFETs.
VCO board #2![](https://live.staticflickr.com/65535/53715950871_c14c11d665.jpg)
![](https://live.staticflickr.com/65535/53715037762_e5c2c02cef.jpg)
This is similar to the other board, except the VCO module's output gets fed to a Merrimac FDF-4A-750 frequency doubler, amplified by an (upside-down) transistor, and then sent off-board.
![](https://live.staticflickr.com/65535/53716161428_f695002328.jpg)
Oops, looks like the VCO module here took a dent:
![](https://live.staticflickr.com/65535/53716290299_637cfd9c42.jpg)
This VCO module is an HO1313 model made by RF Monolithics Inc., and the patent number referenced on the case (
US4760352) refers to an oscillator tuned by, again, a SAW filter. The
HO1300 and
HO1301 are 700 Mhz and 750 Mhz SAW oscillators in the same series, which look similar even down to the pinout. The difference, besides presumably the frequency, is the "hi-rel" packaging here which might explain the lack of available datasheets if they gave it a custom part number for the special application. I'm going to assume that like the other VCO, though, this oscillator works somewhere in the high-100s-of-Mhz / low-Ghz range.
Let's open up this one too and compare the internals:
![](https://live.staticflickr.com/65535/53715952131_0ca0a0f83d_c.jpg)
![](https://live.staticflickr.com/65535/53716291224_ab33803ab9_c.jpg)
![](https://www.eevblog.com/forum/rf-microwave/interesting-unusual-rfmicrowave-boards/?action=dlattach;attach=2194363;image)
![](https://www.eevblog.com/forum/rf-microwave/interesting-unusual-rfmicrowave-boards/?action=dlattach;attach=2194369;image)
This one is much simpler than the other, based around just a single amplifier: the
µPC1677. If you scroll to the 2nd page of that datasheet though, you can see it's not just a single transistor, but a whole 8-transistor amplifier circuit, 4 of which are diode-connected likely for DC biasing.
This VCO circuit is different in that it lacks a separate output buffer circuit, and it also uses a lot of winding PCB traces instead of inductors: I haven't measured lengths and substrate thickness, but this suggests it may be working up in the low-Ghz range as opposed to the other VCO. It also has a resistive power splitter to divide the oscillator output between feedback network and output pin, which is much lossier (dissipates half the output power) but I'm guessing the lossiness also might make it less susceptible to "load pull" on the oscillator output, making the output buffer amp unnecessary? (I haven't worked through the math on that either though)
The varactor-tuned portion of the feedback network is interesting, with 6 identical back-to-back varactors fed the same bias voltage: this amplifies the capacitance variation, and therefore the tuning range, of a single one of these varactors by 6x. The back-to-back configuration also I think should help cancel out some of the asymmetric non-linearities (= even harmonics) created by the RF signal moving each varactor back and forth slightly along its tuning curve. The SAW filter here also gets its own supply voltage, which suggests that there's either some kind of electrostatic thing in there that needs a DC bias, or that it has its own internal amplifier (either to drive the transmitter, or the amplify the signal from the receiver).
Anyways, hope you enjoyed - let me know of any mistakes I made interpreting the VCO circuitry.
