Author Topic: Interesting Aerial Facilities PIN switch (?)  (Read 1730 times)
Offline wkbTopic starter
« on: November 21, 2016, 07:52:11 pm »
Found this cutie on a HAM fair here in PA country (the Netherlands).
Manufacturer is Aerial Facilites Ltd, and it was hand marked as "70MHz" stuff.  Does anyone on this forum have any info on this beast?
I am curious about the 'coiled' interconnects between the chambers in the milled-aluminium box.  It looks like very thin semi-rigid coax.
Any clues?
tnx Wilko
Offline w2aew
    • My YouTube Channel
Re: Interesting Aerial Facilities PIN switch (?)
« Reply #1 on: November 21, 2016, 09:38:54 pm »
Those coiled sections could be 1/4 wave transmission lines, which could be used in switch applications for things like T/R switches.  I did a video of one such PIN diode based T/R switch (using lumped elements instead of a 1/4 wavelength line).  Here's the video on that, if you're interested:
FAE for Tektronix
The following users thanked this post: julianhigginson
Offline raspberrypi
« Reply #2 on: November 22, 2016, 12:21:39 am »
Great explanation answered all my questions too. Where do you buy the parts to make your inductors?
I'm legally blind so sometimes I ask obvious questions, but its because I can't see well.
Offline langwadt
« Reply #3 on: November 22, 2016, 12:46:37 am »
in NMR it is commonly done passively, basically the same circuit just skip the control and replace each diode with a set of antiparallel diodes
Offline w2aew
« Reply #4 on: November 22, 2016, 03:21:33 am »
I get a lot of my toroids from here: http://kitsandparts.com/ or here: http://qrpme.com/?p=product&id=PT
FAE for Tektronix
