I am using this 32kihz Crystal, and my requirements need long term accuracy while I don't care about stability between pulses. Can I actually assume that the error caused by instability has a gaussian distribution? Ie, is it realistic to ignore the stability spec when speccing the drift tolerance of the clock?
Assume that I correctly calibrated the short term accuracy using a sample of a few minutes worth of counting clock cycles. Each unit is calibrated in production using an inhibition compensation technique.
