you need to put a cable raceway for it, its a piece of metal, or plastic, that has a slot for the cable to go under, that protests it from being garbed on stuff, usually its pretty soft but you can get a tougher one that you can walk on.
When you see cable duct taped to the floor it means a very cheap person or idiot
for instance
https://www.electriduct.com/electriduct-crown-molding-pvc-cable-raceways.htmlits meant to be a pretty
architectural detail, so you are supposed to spend the time to do it nice like trim carpentry and select it like a interior decorator. no pipe please
there is tons of different kind, you can make your own too out of a bunch of different methods. raceway looks nice, a PVC pipe looks like expedient afgan shit, I don't recommend that unless its the shop lol
Ideally you want to extend the cable so it runs along the edges of a room, it should not run diagonally over the floor , etc.. it should be mop, vacuum, chair leg, and pet safe. This may involve splicing fiber optic, which i have no experience with.
When you run a cable on the floor expect bruises, missing teeth and destroyed equipment lol (if you are young, old people might end up in a cast).
Panduit corporation and electriduct would be good high end places to start looking for the correct protection.. panduit is a primo manufacturer.
