Is it possible that the "horn" is a series of slot antennas and the one they drive controls the direction of the pattern as a means to track satellites? Starlink uses a phased array of slot antennas from a flat surface to achieve directionality. Perhaps this is similar, but instead of phasing slots, it simply chooses one, then moves to the next and the shape of the reflector does the rest.
