For example, imagine a large number of smart-phones moving around a large campus area and being elements in a vast synthetic aperture phased array able to dynamically beam form in real time while all the elements are moving around randomly!! You can imagine the enormous computational power required for this to work, yet all was condensed into a single ~1 Billion Device chip over a decade ago!!!
And how are the nodes (a) precisely time and phase synchronized and (b) controlled ?
I understand the theoretical part of this, but fail to see how it could practically be implemented on a large (kilometers) geographical scale.
Well that's just one of the many "You can't do that!!" parts of CLASS!!
The original solutions came out of MIT Lincoln Labs a couple decades ago, then DARPA developed a program to implement such with a few other "You can't do that's"
As you can imagine the signal processing is quite involved, and as the DARPA site mentions requires 1000X our processing power to unravel, and our chip was already at the edge of "Supercomputer" performance (mind this a dedicated processing chip, not GP)!!
Edit: Sometimes things are going on "behind the scenes" that seem impossible to knowledgable folks, take for example Stuxnet, or the half century old GPS position recovery from GPS denied locations, reading fiber optic cable data non-invasively, or more recently the PolyPhase Mixer (PPM), which breaks mixer theoretical noise figure limit below 3.92dB, and a bunch of other stuff that's not for open discussion!!
Fondly remember discussing the PolyPhase Mixer (PPM) with a couple DARPA Program Managers at an IEEE Conference, both were well seasoned RF/MW/Signal Processing Expert Professors. Being from DARPA they are always looking for "You can't do that stuff", skeptical but took note, and later we had a program to develop the PPM. We were told to present initial work at MIT LL and later DARPA created a workshop at Headquarters where there was standing room only. There was quite a bit of skepticism involved since the PPM violated conventional Mixer theory wrt Noise Figure.
After answering a few questions and finishing (thought so), one of the most notorious intellectual shedder professors (Distinguished Chancellor West Coast Prof) siting in the front row hadn't said anything, then said "Mike explain to me why the NF is below theoretical?" So we had a back and forth discussion about my reasoning as to why, which he initially whole heartedly disagreed with, then finally said OK I can accept that explanation!!!!
My public intellectual execution had been "Stayed"
https://www.eevblog.com/forum/rf-microwave/polyphase-or-n-path-mixer/msg3381802/#msg3381802Best,
