As promised, now that Christmas is finally over, some more input.
Setup:
I used a switchable attenuator and measured S21. So nothing too complicated.
Here you see the recording of the value at 4 GHz, sampled every second and for 30 seconds.
After a few seconds I did switch the attenuator to higher attenuation. Obviously it's of very high precision at 4 GHz.
The software is made as such:
If you start the measurement, it will set the center-frequency of the VNA to the frequency you did set, span is set to zero and a marker is put onto the frequency chosen.
Then the value is read every interval, you did chose. This does not work perfectly as the time until data-transfer is giving a significant delay. Instead of 5 data-points every 5 seconds, you get around 4.
I will check on methods to speed this up, but there seems to be limits inside the 8510 on answering data-request.
Next steps will be:
- Include calibrated measurements (-> Load appropriate cal-set)
- Polish the overall usability (view-options, saving of data, persistent config and so on) <- That's a lot of work behind the scenes
- I did start on this beeper, that needs to be finished.
Once that is done, I will publish a first version (hopefully I manage in the next days). And then start to work on new features.
It is possible to emulate the time-domain security key with a relatively cheap FPGA board (Mojo V3), and I would definitely recommend doing that if yours doesn't have the key. It's amazingly useful. If you manage to emulate it on the PC, you'll probably want to be able to compare the results.
Thanks. Yes I saw this procedure on KO4BB's site. The "security"-Boards including the Option-PAL are also available on eBay once in a while.
I'm not so sure about the compatibility with my firmware-version. Maybe I get one of these FPGAs, but I'm rather lazy atm, as my other "low-freq" VNA up to 1.3 GHz can do this and for finding faults in cables the unit also okay.
But I guess, even if it's just for the sake of completeness, I will do it some time in the future
Will have to dig into the 8510 anyway to change the lithium-battery sometime 2019.
