Author Topic: Help understand emission level from GSM booster. Is it safe for health?  (Read 7568 times)
Offline HousemanTopic starter
Hi forum.
I really need your help in order to understand if it is safe or not.
Inside my house I have very poor 2G/3G/4G cellular signal.
Calls are only possible in a specific point of the house outside the window where I get at fairly decent signal.
So I have bought a Chinese quad-band BOOSTER that consists of an external antenna / an 2G-G-4G amplifier and / a internal stylus antenna.
I have placed the external antenna at that point and now inside I can make calls.
Now I am concerning about safety especially since I have a young child playing around.
Item does not have a CE certification.
So I have measured with a spectrum analyzer a 3-meter distance and get the graph showed in the files.
The signal is at least 34dBm above the noise floor with a peak of -42dBm.
It can be shown the two frequency bands occupied.
How information can I extract from this graph?
I do not want to have a harmful device inside my house.
Can you suggest me some other test to perform in order to understand better?
Thank You so much.
Best regards
Steve
Offline Qw3rtzuiop
Re: Help understand emission level from GSM booster. Is it safe for health?
« Reply #1 on: November 06, 2020, 02:05:51 pm »
The maximum exposure levels are usually given in V/m (electric field strength). To get this value you need the voltage and the antenna factor.
https://www.keysight.com/main/editorial.jspx?cc=DE&lc=ger&ckey=1000001962:epsg:faq&nid=-33762.752176&id=1000001962:epsg:faq
You can take a look at the exposure limits given by the ICNIRP. But most countries define a lower limit for endless exposure times. Usually ca. 90 V/m at GSM900.
Online radiolistener
  • Country: ua
« Reply #2 on: November 06, 2020, 03:53:59 pm »
Signal level depends on antenna which you're using, so you're needs to perform the same measurement with the same antenna for known signal level in order to get absolute value.
In other words, you're needs calibration with reference source.
« Last Edit: November 06, 2020, 03:56:00 pm by radiolistener »
Offline Tom45
« Reply #3 on: November 06, 2020, 05:14:25 pm »
It would be interesting to do the same measurement for your phone to see how it compares.
Offline geggi1
« Reply #4 on: November 08, 2020, 08:08:16 pm »
-30 dBm is 1 micro watt.
-34 dBm is less than half a microwatt.
a mobilephone is somwhere in the range of 200 mili watt  or about 23dBm.
Your phone is radiating somewhere close to 400 times more and is considerable more than your phone repeater.
  • Country: ua
« Reply #5 on: November 08, 2020, 08:36:27 pm »
geggi1, we don't know physical size and efficiency of antenna and test setup which was used for measurement, so we cannot make assumptions if power flux density level is within safe range. It can exceed safe level or not. We don't know. Because we don't know what absolute level corresponds to 0 dB on his measurement
« Last Edit: November 08, 2020, 08:40:33 pm by radiolistener »
Offline Lord of nothing
  • Country: at
« Reply #6 on: November 17, 2020, 08:50:08 pm »
Well if its true and you are from Italy you should know that is illegal to use such think.
Made in Japan, destroyed in Sulz im Wienerwald.
Offline E Kafeman
    • AnTune VNA software
« Reply #7 on: November 20, 2020, 11:28:22 am »
Measured and by antenna picked up power, here -30 dBm,  can be assumed that it is in same range as amount of power that can be picked up by a human body at similar distance.
It is dangerous as it is EM waves transferring energy which is creating heat when these waves are absorbed in skin and fat close to surface of human body.
It is easy measured with a simple thermometer how much skin-temperature is increased.
Human body have inbuilt functions trying to handle local heating. Typical methods is by increasing blood flow to spread heat more even over a bigger area and then emit that heat with aid of sweat transpiration.
More intense heat and body reacts with reflexes trying to avoid touching a very warm surface, such as a hot soldering iron.
Measured amount of power is less then -30 dBm. It corresponds to 0.000001 Watt
Assume a human body can absorb ten times more power then your antenna, it is ten times more effective as antenna, and resulting absorbed power is 0.00001W.
We can compare this to other sources of same kind of EM waves.
A 1W flashlight pointing against directly at your body makes your body receive 100.000 times more radiation and it will induce much higher levels of heat locally at your body. Depth of radiation under your skin is similar as for 900 MHz EM waves, 99,9% of all radiation is absorbed within 10mm below skin, but heat will continue to spread deeper even after flashlight is turned of.
The biggest and strongest local EM source we know about is hanging outside, our sun. At a clear day will sun emits peak 2000W/m² at earth surface. As an adult human body expose about 1 m² of surface against sun if not using protecting clothes can we absorb up to half of that 2000W and the other half is reflected if it is a pale skin. Absorbed amount of power is then then about 1000W. Really a lot of heat to handle. Body internal cooling system have to run as hard as possible to avoid permanent harm and adding as much coolant liquid as possible is often important a sunny and warm day.
As with all kinds of radiation is time a critical factor when comparing resulting radiation wounds.
Say that a terrible accident happen and you get exposed by sun for 1 minute totally unprotected. Amount of absorbed energy in your body is then equal to amount of energy absorbed 3m away from your repeater during a period of 1900 years.
Turn it the other way, avoid sun for one minute and you have compensated for your router RF radiation for 1900 years.
As radiation levels decay with square of distance, keep at least 50 meter distance from heating elements inside house.
A kitchen stove can easily emit a 2000-3000 Watts and the closer you are, the bigger risk for burning wounds.
Burning risk is here a factor exactly same as for a flashlight or a cellphone which can emit up to +30 dBm (1W), about 1 million times stronger then your measured -30 dBm from repeater.
If measuring a active cellphone from 3m distance will probably show similar result as for the router.
Difference is that cellphone is often held at a much shorter distance then 3m.
Be also aware of risk due to EM waves radiated from light bulbs indoor. They emits often more then 10W, not seldom close to your eyes.
Even worse, a computer screen is sending waves directly against your face and eyes, not seldom with 50W or even a bit more, including IR waves.
EM waves are causing heat effects but with increasing frequency increase level of sporadic harm at atomic level. A such harm is when a subatomic particle is kicked away from its atom, a first step to cause permanent cell modification. That danger increase with frequency. For frequencies corresponding to visible light-waves is it almost never possible to kick atomic particles away from its atom as needed energy level is too high.
For next known frequency range upward, UV-waves is it more possible and at even higher frequencies, x-ray, is it potential even more harmful as almost all radiation now is in shape of particle radiation and no EM waves.
It is same type of X-ray that is radiating at us in higher amount when traveling with airplane or when examine teethes at dentist.
For real low frequencies, almost DC, such as 900MHz which is at least a million times lower frequency then UV is it really not even possible to kick away an electron from its atom as needed energy level to do so not is even theoretical is possible.
Even lower frequencies with high radiation levels found in in many houses is in frequency range 50 or 60 Hz and is emitted in real high amount as magnetic radiation. Human body is way to short antenna to become an absorbent of energy at these wavelengths. Only possible way to absorb energy at these frequencies is by direct connection between electrical wires and body.
Even at real small distance between an electrical wire and skin, and transferred energy is much reduced.
From above examples, it is a clear relation between EM wave frequencies and human body efficiency as a wireless receiver.
Question "is GSM booster radiation levels safe for health" can with above text now be better put in perspective.
The booster consumes probably 10W but emits max 1W at relative safe frequency, 900MHz. It is the remaining 9W that are more dangerous as they not just goes up in smoke, but are emitted as heat-loss within IR-range, which is much more dangerous due to its higher frequency compared to 900 MHz. IR is slightly less harmful then light bulbs that radiates mainly at higher frequencies but as it is around 400 THz is it 400 times higher frequency then 900MHz.
If radiation levels corresponding to a 10W light bulb or more not exist inside your house, and if all window are blocked from sunlight entering inside house and emits its radiation, yes heat loss from your repeater, all 10W of it, are a risk for your health as it now a dominating radiation source in your house, as long as it not is any human bodies inside house as such emits a lot more radiation.
If absolute no radiation sources exist inside your house, it is a disadvantage as temperature then not can go above absolute zero, -273C.
To keep temperature in balance must human body and its surrounding constant absorb about same amount of radiation as it emits.
A human body will die within a minute without any external radiation.
Your body is a radiation source, emits 100W or more of heat that may be absorbed by other human bodies. Emitted in IR range. Your body is also a dangerous wave-converter, as it converts absorbed less harmful 900MHz radiation to IR-radiation that then can be re-emitted to surrounding environment.
Avoid radiation emitted from other humans and avoid sun-radiation, both are scientifically proved dangerous for your health.
Health problem due to GSM-repeater is harder to measure as its radiation level often is so much weaker then more possible harmful radiation sources in same room, such as a light bulb or a heating element, which is assumed to be relative safe.
Why fear 1000W at 900MHz, causing about same amount of heat radiation as a conventional electrical heating element at that amount of power?
Government regulation related healthy or unsafe radiation level are all based on guessed fear level, as it not exist any scientific prof in any direction for any disease or harm, except for known facts that EM-waves absorbs as heat and nothing else.
Our strongest source of all sorts radiation, the sun, is however less regulated.
Radiation-levels levels from sun is known that we can survive for at least shorter periods, which is our practical health level.
Even hotter or sunshine for too long period is uncomfortable,. Can cause dangerous dehydration and skin burn.
With low amount protecting ozone can UV-radiation from sun faster reach dangerous levels at which permanent cell-wounds can occur. Most of these wound are repaired automatically. If not, can it result in dangerous health problem.
Eyes is a special problem.  Eyes can be burnt by sun at an even shorter time then skin as an eye can focus radiation to a smaller spot, causing short period with high intensity of radiation in bottom of eye. That kind of wound can not allways be repaired by body itself or by doctors..
That problem does not exist at 900MHz as wavelength is too low to be focus-able with an optical lens.
Government regulation regarding allowed RF-levels and frequencies,  to avoid interfere other equipment or blocking frequencies used for important communication should be respected.
On the other hand, if living in a very rural place where radio/telephone/TV-signals are weak due to long distance or blocking terrain and no neighbors, will signals you equipment generate be equally blocked in other direction by same terrain.
Airplane communication can still be interfered even from a rural place, but it is a seldom reported problem.
Known such interference with airplane communication have been mostly close to airport, near or at ground.
« Last Edit: November 20, 2020, 11:36:48 am by E Kafeman »
No signature
« Reply #8 on: November 27, 2020, 07:56:49 pm »
What is illegal?
Using a phone booster to power up signal strength?
  • Country: at
« Reply #9 on: November 27, 2020, 08:15:27 pm »
Yes!
« Reply #10 on: November 27, 2020, 09:04:50 pm »
Yes!
Uh, didn't never know actually.Sorry Why?
It's a CE certification question or something else?
Please tell me.
  • Country: at
« Reply #11 on: November 27, 2020, 09:08:23 pm »
 ;) Simple only the Cellphone Operator are permit to Transmit on the Band the "Rent" from the Goverment for a LOT of Money.
Offline dropkick
« Reply #12 on: November 27, 2020, 09:25:25 pm »
The booster is likely no more powerful at distance than a regular wi-fi access point. Don't worry about it.  Your phone may actually reduce its power as well, thinking it is closer to the cell tower than it really is.
I'm not sure about Italty, but for example in the US boosters are "basically" allowed, but must have at least some sort review by the cellular carriers as "ok" to use with their system.  They want to limit power, insure quality of signal, etc., as to avoid interference with the rest of the system.  There is probably some FCC regulation too (our govering body for RF) likely the Part 15 low power allowance.  That being said I'm sure there are lots of crappy imports in use.  This is why carriers frown upon them.
We have two types of cellular helping devices, boosters and pico/femto/"small sized" nodes.  The boosters do just that, they attempt boost/repeat/amplify the existing recieved over air signals at a location and are often used in rural areas with a directional antenna pointed at town.  Results are mixed as they're not terribly intelligent devices, just amplifying what they hear and hoping for the best.  The other type are basically little full duplex cell sites in a box with a connection to your home internet for backhaul. These are sold by the individual carriers for use on their specific network only and are generally preferred--provided you have internet!
The following users thanked this post: Houseman
Offline cdev
« Reply #13 on: November 27, 2020, 09:31:24 pm »
If I were you I would put send back the GSM booster unless somebody at your cell network tells you its okay.
Instead, set up a passive system with a directional (I would use a log periodic antenna) connected to an indoor omni antenna, connected with a length of LMR-400 or similar low loss 50 ohm coax cable. KIeep the coax as short as you can.
As it does not transmit this is safe and legal. Point the directional antenna at your nearest, strongest cell site.
This will act like a bidirectional tunnel for the signals. It doesn't have to be strong, just give them a way around the obstacle in both directions.
I would not use non-type accepted devices, you might get in trouble. If that doesn't work, ask your cellular network provider if they rent or lend out a cell extender device of the appropriate, legal kind, or have any other ideas. They will appreciate your coming to them and asking.
I hope that I am making it clear that all this is is two antennas with some coax between them.
Another way to extend signals is using a reflector of some kind to reflect the signals like  a mirror, both ways, but like a mirror the placement of that would be difficult at best.
Back in the day some rural areas used setups like this to extend cell phone service to residents down in valleys. It takes no power at all.
« Last Edit: November 27, 2020, 09:40:01 pm by cdev »
The following users thanked this post: Lord of nothing, Houseman
  • Country: at
« Reply #14 on: November 27, 2020, 09:52:16 pm »
that will not happen in 99,XX% of all Case. A long time ago we had a Cellphone Shop in the City with thick moist Walls and a brand new Thermal Isolated Glass Window. Gues what happen?
Indoor quite 0 Signals... Thankfully one of the Operator gave us an Repeater who just worked with there Network and dont inter fear other.
Back then it was a former model of that:
https://coiler.com.tw/at-series/
Please note its NOT legal to use them without PERMISSION.
Offline HB9EVI
« Reply #15 on: November 27, 2020, 10:26:02 pm »
it should be mentioned, that not every body tissue has the same sensibilty on non-ionizing radiation. In the microwave range, for example on the 2.4GHz ISM band should be taken care to protect eyes; they contain a very high percentage of water, and we all know, why microwage ovens operate on 2,4GHz. When transmitting with my 20W on 2,4GHz in the 95cm dish, there is a strict ban passing within a 4,5m range in front of the dish due to high radiation level.
that's one side of the topic, the other is the following:
clearly those booster, if now for GSM/UMTS/LTE or wifi are not allowed to use; most of those devices don't even meet the specs of spurious emissions.
I got me a 20W wifi booster for my QO100 setup, like expected it came without any LPF. it's of absolutley no interest, if there is a CE label on the device or not. mobile operators pay an enormous amout of money to get the permit to use the frequencies, the requirement they have to meet (and the end user devices too) are strictly regulated. On the wifi frequencies are regulations concerning the maximal emitted radiation, which is in most of europe 100mW EIRP, so even if a booster meets spurious emissions, it exceeds the legal limit quite fast.
if it really goes bad, customs forward such an article to the measurement place of the regulation authority. Not only the article will be gone, but a proper fee for the measurement and maybe a fine can be applied to the buyer. not even as a ham you are safe to buy those articles
« Last Edit: November 27, 2020, 10:27:57 pm by HB9EVI »
« Reply #16 on: November 27, 2020, 10:35:36 pm »
Now I understand.Thank You very much all for the explanation. I am actually confined in a rural land in the mountains 600 mt. above the sea, locked in grandma's old house with thick walls due to severe COVID restrictions here in North of Italy. We are not allowed to even get out the door. As most of other countries...
Inside the home no way to have even GSM working, (no 4G at all.. only outside in one part of the house I have "decent" 3G signal) Due to particular topographic morphology the house is, even if at height sufficient to see 100km far away in clear days, inside a basin. Trees and a small hill near hides me from the nearest BTS station (it's less than 400meters air line from me but the hill is hiding it. If I overcome the hill I get strong 4G signal and a terrible 150Mbps download link !! ).
The other nearest BTS is in the main town below me at 100mt sea level. I am 500 meters higher. So I think I cannot get the signal from it since as I remember BTS antennas are pointed tilted a little bit down and can't irradiate above the horizon line maybe by some sort of scattering right?
The other three BTS are in the same situation. So I used this booster to amplify a weak signal far away and get decent calls. Not every time, most in Band 8 - 900Mhz sometimes it hops and cannot find anything,
  • Country: at
« Reply #17 on: November 27, 2020, 10:51:30 pm »
Well that is and still be illegal. Point.
Look online for an (used, unlocked) Huawei Router with an external Antenna Port.
Back then there where some who have an Phone Port to make calls with.
« Reply #18 on: November 27, 2020, 10:58:25 pm »
CDEV Thank You very much!!, I have already spent money to lay a lossless 50Ohm - 6 GHz BW line (with connectors that has to be with the shielding coax line "combed"  :D) from the log periodic antenna at roof to the booster inside the house.
I had already noticed that the signal was increased even with booster powered off.
And in a desperate way during a no-signal-even-with-booster-on moment to I had also tried to lay the coax cable behind the cellphone with no effort. Tomorrow I will try to terminate it with a omnidirectional antenna at the end as you say
Now I am asking You following. Inside our family we have two carriers obviously served by two different BTS located obviously one NORTH and the other WEST with respect to the house. I have two Yagi Antenna, How to combinate them? I have found online a GSM combinator wave guide? thank You
« Reply #19 on: November 27, 2020, 11:02:42 pm »
Of course, thank You for the warning, I will act accordingly. I don't want to get in any troubles. Will trash it and use a passive method CDEV has suggested.
Thank You for the hint of the router. But how to get it working if I have no signal at all inside and outside??
Regards
  • Country: at
« Reply #20 on: November 27, 2020, 11:13:13 pm »
Well since you use an Booster you must have an Signal Out there.
You hang an Router on an good directional Antenna who have the right Frequency.
If you want have a more permanent setup you can put the Router into a Water Tide Box and use a short Antenna Cable to the Antenna.
Well looking into Ebay and some local Version of and buy one who you like.
I guess the Speed is not that important for you. Look on the Back of the Router before you buy it if the have a Telefon Line Port. You can use a (cheap) DECT Phone and run arround Home if your Fare include Minutes.
Offline cdev
« Reply #21 on: November 28, 2020, 12:34:41 am »
You could also use an external atenna if your phone has a jack for one. Look for a small rubber plug covering it. If so you'll need a short flexible purpose built coax adapter, which is often called a "pigtail" to connect to the antenna.
I would use a coaxial switch or simply connect whichever one works best at that moment.
You might also want to consider buying a cell phone thats specifically meant to be used stationary in a home, connected to a permanently aimed roof antenna.
The kind of antenna I would use (because it covers multiple cellphone bands) is a log periodic antenna, they are triangular and look like a Yagi but a triangle or arrowhead shape. You can also buy one that meant to be kept indoors that is just a bare PCB antenna, these are very cheap. But it would have to be kept indoors and aimed out of a window, and kept aimed. Keep the coax short because there is a lot of loss at higher frequencies.
Thinking about it a dedicated base-station phone sounds like the best idea. You'd have to use it like a conventional phone, in other words, no portability, but it has the best likelihood of being able to both receive and make outgoing calls. In other words, approximate a wired phone in reliability.
Instead, set up a passive system with a directional (I would use a log periodic antenna) connected to an indoor omni antenna, connected with a length of LMR-400 or similar low loss 50 ohm coax cable. Keep the coax as short as you can.
If you want to try you could terminate both the antennas with two omni antennas indoors, but see above for what sounds to me like the best solution. A base station phone thats designed for exactly this kind of condition.
« Reply #22 on: November 28, 2020, 08:28:56 am »
do I need to stay below the horizontal line sight of the bTS or do I have any change to get it from above?
  • Country: at
« Reply #23 on: November 28, 2020, 09:02:29 am »
You can rotate your Antenna and test the signal strength by 90 Degree on an Router since the Antenna are orientated in different orientation.
Offline CJay
« Reply #24 on: November 28, 2020, 10:52:45 am »
While I wouldn't worry about the RF exposure, it's not true to say they're no more powerful than a WiFi access point, the first one I bought* at a flea market had a Hitachi 2W PA module in it, all the ones I've bought since have had 1W or higher PA modules so they're capable of 10 to 20x more power than a (legal) WiFi access point.
As for the OP, I wonder is it possible to enable 'WiFi calling' on the phone (s)?
In low cell signal strength areas (the back of my house for instance) the phone then routes calls over WiFi to the broadband service instead of via cell tower, it works really well for me.
* I bought it because I was curious and it was very cheap, turns out they have a very useful selection of MMIC and other devices that can be re-used as well as coming in pretty nice extruded aluminium heatsink/case, I've never paid more than £3 for them so they're a bargain for the parts.
« Last Edit: November 28, 2020, 10:55:42 am by CJay »
