it says this in the service manual: The RF signal is fed to the Schottky barrier diode
ring module, Q1008 (ND487C2-3 R), where the RF
signal is mixed with a local signal delivered from
91012 ( 2SC2407 ) ,
_
resulting in a first IF of 8.9 875
MHz. The input and output of the diode ring are
protected by 50 ohm attenuators, which stabilize
the input and output terminations for optimum
intercept characteristics. The IF signal is then
amplified by mixer post-amp Q1009 ( 2SC2407) and
fed to pin 5 of J 1 0'01 for delivery to the IF Unit.
so do i pick off the if sig from pin 5 of j1001 then?
