Author Topic: Harmonic conversion -- Any favorite mixers?  (Read 987 times)
Offline ezalysTopic starter
« on: November 04, 2023, 03:02:58 am »
I'd like to have an auxiliary receiver dedicated to IQ mixer balancing -- that is, I want to discriminate three tones about 50 MHz apart with 30 dB of dynamic range at a frequency of 6 GHz to 12 GHz. To do this cheaply and simply, I'd like to alias down from NxLO + RF. Does anyone have experience doing this? Are there some inexpensive mixers that are better suited for this than others? It seems like designs that do this don't use mixers that are necessarily specified for it, so is it a matter of testing and figuring out which ones work best?
Offline KE5FX
    • KE5FX.COM
Re: Harmonic conversion -- Any favorite mixers?
« Reply #1 on: November 04, 2023, 05:25:54 am »
What's the application, and do you already have RF ADC(s) in the block diagram?  If you only need 30 dB of dynamic range, you might be surprised at how well some RF ADCs can work in (very!) high Nyquist zones, well beyond their rated specs.
« Reply #2 on: November 04, 2023, 01:54:23 pm »
No ADC. Just looking for a suitable mixer. Ideally better than 30 dB!
