Author Topic: GPS antenna matching  (Read 990 times)
Offline rilliamTopic starter
« on: April 22, 2019, 09:46:19 am »
If I modify this circuit by replacing the chip antenna with a sma connector, do I need to change C1,C2,L1 ?
Offline Rerouter
Re: GPS antenna matching
« Reply #1 on: April 22, 2019, 09:48:43 am »
The chip antenna is 50 ohm, and those components would be the matching network for 50 ohms, looks like you should be fine.
