well, if the main points are NVIS and getting down to 80m an aperiodic antenna built using just a run of coax may fit; pick about 21m (69ft) of coax, RG8 will do, shorten one end (solder center and braid together), connect the other end to a SO239 but wiring it "in reverse", that is coax braid to the SO239 center pin and coax center conductor to the SO239 "ground", lay out the resulting coax antenna as an inverted V, connect it to the coax feedline going to the shack adding a decent choke at the SO239 and there you go, use an ATU to adapt the impedance, the resulting antenna will work from at least 10 meters down to 80 meters, but don't expect miracles
