Author Topic: Microstrip High- and Low-Impedance Short-Line Sections  (Read 2695 times)
Offline promachTopic starter
« on: July 29, 2019, 08:37:25 am »
Expression 4.50 can be obtained by equating the ABCD parameters of the two circuits ?
Could anyone advise ?
Note: Screenshots below are taken from Microstrip Filters for RF Microwave Applications, 2nd Edition
« Last Edit: August 17, 2019, 03:35:05 pm by promach »
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
Re: Microstrip High- and Low-Impedance Short-Line Sections
« Reply #1 on: July 29, 2019, 10:02:33 am »
It literally says that they can be obtained from the ABCD parameters.
What you can try is look up is the following:
  • How to go from a difference in impedance to ABCD parameters
  • How to go from lumped components to ABCD parameters
  • How to deal with electrical length in ABCD parameters
And from what you learn about this, you should try and set up the ABCD parameters for both the situations and show equivalence.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
« Reply #2 on: July 30, 2019, 03:10:03 am »
Now the question is how to derive expression 4.50 given the following ABCD matrix ?
I am still trying to derive the ABCD matrix for the following circuit configuration.
Any help ?
Edit : The derivation process could be found at page 25 of the pdf attachment
* Microwave_Network_Parameter.pdf (387.32 kB - downloaded 79 times.)
« Last Edit: October 18, 2019, 01:21:21 am by promach »
« Reply #3 on: August 14, 2019, 07:02:38 am »
The following is the derivation process for expression 4.50
ABCD matrix for transmission line at Figure 4.7(a)
ABCD matrix for π-circuit network at Figure 4.7(b)
Comparing the two ABCD matrices above gives :
Applying trigonometry double angle formula :
« Last Edit: August 17, 2019, 08:10:16 am by promach »
« Reply #4 on: August 17, 2019, 03:40:11 pm »
Ok, now to more detailed part:
How to derive expressions (5.3) ?
I suppose that this involves eliminating the assumption : ZC << Z0 << ZL
Note: In the post above, I have derived expression (5.2) for inductor, which is equivalent to expression (4.50)
« Last Edit: August 17, 2019, 03:47:08 pm by promach »
« Reply #5 on: August 09, 2020, 01:00:02 pm »
The following is the derivation process for expression 4.52
ABCD matrix for transmission line at Figure 4.8(a)
ABCD matrix for T-circuit network at Figure 4.8(b)
« Reply #6 on: August 09, 2020, 01:05:02 pm »
Summarizing the derivation result from reply #3 and reply #5 , we could derive equation (5.3) easily.
However, what I do not understand is why the extra term for the inductor equation (5.3) is labeled as "shunt susceptance of the high-impedance line" ?
If I am not wrong, the book might have a typo mistake and the correct version of the sentence should be as follows :
The results of Eq. (5.2) do not take into account the series reactance of the HIGH-impedance line and shunt susceptance of the LOW-impedance lines.
« Last Edit: August 09, 2020, 03:40:57 pm by promach »
