Author Topic: GNU Radio and APRS  (Read 1279 times)
Offline sarbogTopic starter
GNU Radio and APRS
« on: June 30, 2022, 09:32:32 pm »
I made modifications to the project   gr-APRS - A GNU Radio Block for Receiving APRS  at https://handiko.github.io/gr-APRS/
to work with GNU-Radio 3.10.2.0  on Ubuntu 22.04
Below are screenshots of the flow graph and output.  The PDU vector contents are visible lower left and AX.25 packet on bottom.
Note: A modification is needed to the software that converts from HDLC to AX.25 to avoid the error "Unexpected stop of address section"
Re: GNU Radio and APRS
« Reply #1 on: June 30, 2022, 09:38:52 pm »
The only file I modified was   gr-APRS/Examples/APRS_RX_RTL.grc
« Reply #2 on: July 03, 2022, 11:36:49 pm »
Well......  the   embedded  HDLC to AX.25    blocks  needs lots of work!
« Last Edit: July 06, 2022, 12:49:36 am by sarbog »
