Author Topic: sealectro coaxial to PCB cable right angle adapter? (direct solder)  (Read 743 times)
Online coppercone2Topic starter
I am looking for a adapter like this one, but not SMB, one that you directly use to mate a coaxial cable to a circuit board. I have 3 of them, they just say sealectro on them, without a part number. I can't seem to find them on the website. The idea is they do not have any dielectric in them, other then the coaxial base. So you take a piece of coaxial cable, strip it so there is a little bit of center conductor protruding (3mm), then solder it to the adapter, which is already soldered to the board, then you solder the little lid on.
I know it exists because here it is.
Offline mag_therm
Re: sealectro coaxial to PCB cable right angle adapter? (direct solder)
« Reply #1 on: October 20, 2020, 12:48:23 pm »
Search "sealectro" on Surplus Sales of Nebraska.
There is one I saw that looks  a bit like the vertical version of the one you need
« Reply #2 on: October 20, 2020, 05:26:59 pm »
I found some similar stuff on google searching for terminations, but the nebraska website does not appear to have that. nothing gold plated and nice looking like that
very interesting website, it is likely to burglarize me in the future
its practically like 'hey someone took all your money and left these little metal hexagons as a calling card'. like the riddler
« Last Edit: October 20, 2020, 05:29:33 pm by coppercone2 »
