I am waiting to do the 8-12 GHz horn because this one has a busted flange that I filled with JB weld, and its above my test frequency, it only has 3 mounting holes as a result of this. I am going to make up 2L of solution and do a better plate on a higher wave guide size that I can actually measure on VNA
1) I got a 4 inch ID copper tube segment, that is ~0.05% phosphorous, which is ideal for electroplating, compared to random scraps I use that I can form into a proper electrode
2) I got 5um polypropylene fabric coming in mail to make anode bags with
3) make up 2L of plating solution so I can plate without the antenna sitting on bottom of tank almost coming out of water (that is, it can be suspended instead of moored)
there is 100% copper coverage the black is a failure of the kool-amp silver plating to get into the crevices. all defect appear to be because of the poor paint job (it was painted with spray paint squirted into a cup and brush painted after being swirled for a while to degass it and periodically had more paint added to make it liquid, real bootleg)
If you don't do 100% job on the kool amp, it leaves silver oxide (black) on the "not fully rubbed" parts of the surface, my brillo can't get into some of the channels in the corner etc
my fresh tin chloride should come in soon so hopefully I can get away from that god damn conductive paint crap. you could sand the paint down before you work but sanding it was driving me crazy, it keeps clogging sanding sticks and you end up with a 'zoolander' situation where you have 500 clogged manicuring products in the trash
I also bought a 24/40 glass vacuum filtering funnel (non frit but with holes), fine filter disks and a 2L erlynmeyer heavy walled flask so I can filter my baths through a vacuum system using a aspirator to get crap out after a run, and hopefully for the larger tank I can use my battery powered perestalic pump to pump out the electrolyte instead of trying to pour big containers into funnels
I also have my berylium copper fixture springs (curl it up into a spring and clamp it on the object undergoing plating) and titanium tweezers to make the whole process a little cleaner. I still need to get a squirt bottle for distilled water, It got really messy when I kept trying to pour it into a normal funnel to filter it out and swapping containers etc
