Author Topic: Experimenting with waveguides using the LiteVNA  (Read 78500 times)
Offline joeqsmithTopic starter
Re: Experimenting with waveguides using the LiteVNA
« Reply #425 on: May 28, 2023, 05:37:48 pm »
There is that one salvage yard I posted who has a large assortment of waveguide parts.  The problem, they do not provide any details about the dimensions.  If I lived in the north east, it may be worth a road trip just to go though their inventory with a micrometer.
A neodymium magnet next to the cavity and iris.  The nuts, cap screws, spring are all stainless.  A lot of copper, brass and silver.  The only thing ferromagnetic is  the ground shaft of the Sterritt micrometer.
With the limited travel and the micrometer, compared with the old HP adjustable short, it's much easier to tune.   There is also very little backlash, unlike that 1950s HP part.
When I first started out, I did not have to sign an NDA.  I remember reading about two soft heads that worked for TI that had taken home the software they were working on.  TI got search warrants and then sued them both.  Their defense was they found the work interesting and saw no harm in taking it.   Now days, it's more like this:
« Last Edit: May 28, 2023, 05:48:21 pm by joeqsmith »
Offline coppercone2
« Reply #426 on: May 28, 2023, 05:44:38 pm »
did you get the rotating or non rotating head micrometer? Probably does not matter. I mean the starrett that has a key in it so the shaft does not spin and just presses
Offline coppercone2
« Reply #427 on: May 29, 2023, 12:03:22 am »
lmfao need a fork lift first
« Reply #428 on: May 29, 2023, 02:35:31 am »
I imagine the power supply and other equipment that went with it at least doubled the weight.  Your friend ChristofferB was talking about using the X band.  I assume that was partly due to the lower field requirements.  Old though, I never saw once where they measured the field or showed the sweep in operation.   Maybe they were further along than I was able to find but it seemed like more a 4 year thought project.
Offline coppercone2
« Reply #429 on: May 29, 2023, 02:43:55 am »
well I think he is a grad student iirc so the project budget may have been diverted to basic essentials
« Reply #430 on: May 29, 2023, 02:57:07 am »
That last post I had found, it seemed like they had ditched the original idea and started to go in a different direction.  A few people chimed in, including yourself but that was it.   Their signature states "Chemistry phd student!"  but I assume by now they would have graduated.
When they increased the frequency, I assume they knew they needed a field 3X.  But I didn't get the tiny little coils they show having near enough to get the offset they would need.  Maybe.
Offline coppercone2
« Reply #431 on: May 29, 2023, 04:47:31 am »
Oh, lol maybe they got a old one when the first job company replaced the older one to keep their yearly budget :-DD
« Reply #432 on: May 29, 2023, 04:44:33 pm »
Or they eventually realized it wasn't as easy as they first thought and cut their losses.   :-DD
Offline coppercone2
« Reply #433 on: May 29, 2023, 06:03:28 pm »
well every picture I see of those x band type machines they require a fork lift for installation. I never really bothered to figure out what the magnet would look like, I just put the project on the back burner because I figured something ugly would present itself there in some form.
I do like the high current low voltage circuits though, but the biggest I went is that 2000W resistance brazing transformer, though for all its worth I suspect that if I just figured out how to use that in all its capabilities to save on acetylene it would just come back to haunt me when I forget to exercise the gas valves and I need to replace baffles and shit because the tanks go unused for too long. And the wires are too damn heavy,. rather use the 'light' cobra torch, I start thinking of arnold swartsnegger when I wire up that vutron super 0000. That little spot heater I cobble together makes you feel like you are a power loader. I just need to strap the transformer on my back and replace my hand with a large knipex pliers wrench and I am ready for work.... that would be a good exo skelleton too, two pliers wrench hands connected to giant current transformer so you can heat bend I-beam and shit.
tldr: holding objects with heavy hoses or cables makes you feel like a robot
« Last Edit: May 29, 2023, 06:09:06 pm by coppercone2 »
« Reply #434 on: May 29, 2023, 08:43:04 pm »
There is a display of Zavoisky's lab where they have some of his original magnets.   It appeared that ChristofferB was planning to use a combination of fixed magnets and pole piece to get the minimum field, then use a coil to make up the difference and allow them to sweep it.   This would really scale down the size and power required.
« Reply #435 on: May 31, 2023, 10:45:05 pm »
Attempt to 3D print copper and sinter it.   Interesting idea but doesn't look like we can pull it off with our setup.
« Reply #436 on: June 08, 2023, 01:48:02 pm »
Still looking for a better coupler to replace the old Narda part I have been using to measure S11.  The Narda 3095 looks like it would be a good fit.  Cheap, covers the X-band and good directivity.   These use the APC7.  There are some <$15 USD from China.  Searching this site, someone had asked about them a few years ago but I don't see any data.  They advertise them good for 6GHz.  Wonder how they perform at double that frequency.
https://www.eevblog.com/forum/testgear/apc7-to-sma-adapter-from-china-ok/
Cheap APC-7 SMA adapters from China.
https://www.ebay.com/itm/314581375697
Datasheet for couplers
https://nardamiteq.com/product-spec/097-Couplers.pdf
3096, directivity 25dB
https://www.ebay.com/itm/304867686545
3095, directivity 33dB
https://www.ebay.com/itm/304898554282
Offline coppercone2
« Reply #437 on: June 08, 2023, 06:09:34 pm »
Wow you can sinter with a extruder printer?
I am guessing its a high copper content 3d print wire that is then baked in a kiln for burn out and sintering?
I am just waiting for my ground cable to come in for the tig lol, got the wrong gas lens in my kit so I only have the quartz one.
I think usually they say that out side of the frequency band of operation for the next octave you might be able to find a stable narrow region of operation that is potenitally usable in spite of the 'modeing' that occurs. But I have no idea for the band under. I think its potentially usable at a higher frequency for some small random bandwidth, but not with the lower end.. that is a hard cut off I think? Wavelenght too small for wave guide = odd transmission modes, wavelenght too big for wave guide =? (I think its very high reflection but not sure)
from what I understand : the most out of bounds components you have (operating past their max frequency) the less likely you can find a useful transmission band, since each component might have a random area that transmits some frequency but they are not correlated so with more then 1 component you might not have a path through.
« Last Edit: June 08, 2023, 06:20:35 pm by coppercone2 »
« Reply #438 on: June 08, 2023, 07:38:26 pm »
I would say we tried to sinter with an extruder printer.   Yes, as you described.
All of the parts for that extender are fine for the X band now, except that coupler.  Even at 11GHz, it works better than I would expect but this is really the problem.   The mixer's IF is limited to 4GHz but right now, I can't even sweep up that high.
https://www.eevblog.com/forum/rf-microwave/experimenting-with-waveguides-using-the-litevna/msg4850513/#msg4850513
Thinking I may add in that terminated SPDT relay as well so we don't have to move cables.   Eventually, it needs to get mounted into a box but for now I'll leave it as a 3D mess.
« Reply #439 on: June 08, 2023, 08:29:16 pm »
Try finding couplers with over 25 dB directivity.   They are not common.  I want to keep the coupling at 10dB and plan to give up the half dB loss by leaving it in-circuit.   HP offered the 33311B relay with a 5V option.  It seems like it would be a good fit.
https://www.ebay.com/itm/144419029196
Offline coppercone2
« Reply #440 on: June 09, 2023, 12:32:34 am »
here is a 50db coupler
https://www.everythingrf.com/products/waveguide-couplers/flann-microwave/228-248-16133
hidden behind a quote wall.
it appears they are quite long for higher directivity
A 779D or similar is like 30dB.
https://www.romtekonline.com/product-details/multihole-directional-coupler.html
35
might be worth checking the Flann brand out on ebay, they seem to be all that shows up for higher db directivity
https://flann.com/wp-content/uploads/2015/09/Flann-Final-2015-for-Website-Use-06082015.pdf
your finger sir
https://www.ebay.com/itm/175741081773
« Last Edit: June 09, 2023, 12:47:45 am by coppercone2 »
« Reply #441 on: June 09, 2023, 01:50:32 am »
I would have thought you would understand that everything on the extender is coaxial.   That said, it would certainly be possible to make it all using WGs, if size, availability, cost, ease of use.....
Offline coppercone2
« Reply #442 on: June 09, 2023, 01:58:35 am »
nope I read that in between trying to clean this p6015 probe for silicone oil with all the high cleanness procedures and totally forgot, at least i did not spill hot oil anywhere yet
I am suspicious that the silver plating on the high voltage resistors disintegrated into the freon or something, there was alot missing on the resistor. I wonder if that could make it arc over
« Last Edit: June 09, 2023, 02:01:01 am by coppercone2 »
« Reply #443 on: June 09, 2023, 02:59:53 am »
When I designed that wideband HV probe, I didn't want to use anything liquid.   So ceramics and make it large.
Offline coppercone2
« Reply #444 on: June 09, 2023, 03:50:55 am »
I saw your point because of thermal expansion and also bubbles. I was gonna squirt a little bit of butane in there before sealing though, just a drop...
might just have to say... avoid probing awfully low impedance circuits. For limited HV stuff, it should just spark inside of the tube. Would I trust this for probing a HVHC transformer.. nope
kinda wonder what CAT rating this probe would have with freon, with oil, and then the proper redesigned one with oil in it.
Kind of think that a very high current high voltage probe that can explode, should have a HV fuse in front of it, whatever that looks like. Or because of bandwidth reasons, a minimum safe distance... ship it with a tape measure....
« Last Edit: June 09, 2023, 03:56:07 am by coppercone2 »
« Reply #445 on: June 09, 2023, 02:48:13 pm »
Sounds like you bought the 6015 probe without reading the manual first as.  Even without the manual, just looking at the probe I would never have come to the conclusion that this was a good choice for AC mains work.   I take it you have little experience in this area.  This probe is very popular and I bet if you used the sight's search engine, you would find everything there is to know about it.
I have an Agilent 33311 that would work to switch between S11 & S21.   Isolation is good but the insertion loss is about a half dB.   I pulled it out and it is marked Agilent, so it would be newer with potentially less wear but its an A.
https://www.testequipmenthq.com/datasheets/Agilent-33311B-Datasheet.pdf
« Last Edit: June 09, 2023, 03:10:33 pm by joeqsmith »
Offline coppercone2
« Reply #446 on: June 09, 2023, 08:22:16 pm »
I read the manual it says nothing about how big of an arc it can take before it explodes and shoots hot oil (for the 6015A). Say there was a surge on the power lines.
I assume its meant for lab use like from small transformers and such, since its made by tektronix. I.e. bench top isolated circuits. For a house I assume it would arc over some where in the breaker box if that happened anyway like a spark gap. But past the house I don't think I would trust it.
For the A it does say The inputs are not rated for connection to mains or Category II, III, or IV circuits, but for the 6015 it does not have a cat rating
« Last Edit: June 09, 2023, 08:27:08 pm by coppercone2 »
Offline coppercone2
« Reply #447 on: June 09, 2023, 08:55:34 pm »
for the oil fill I used silicone oil that I heated in a beaker with a watch glass on top to 150C for like two hours (using immersion thermometer), let it cool down to be manageable then I passed it through a glass frit vacuum filter into a glass flask (washed and baked all of that) because there was some particles in the oil that I noticed after heating and inspecting with bright light, then poured that into the probe that was washed and baked. Not sure if dust got past the watch glass or the oil was contaminated.
It should probobly be dried in a retort but I don't have one (like the old soup & life biology experiment
« Last Edit: June 09, 2023, 08:59:36 pm by coppercone2 »
« Reply #448 on: June 09, 2023, 09:23:10 pm »
We had the freon filled ones when I started out.  There were no CAT ratings back then and so it should be a surprise that the manual does not mention them.
I have never seen a company say anything about how big of an arc their CAT rated DMM can take before it explodes and shoots hot ....  It's just not something anyone is going to publish.  Again, thinking this is all new to you as I can't think of one time anyone has made such comments about the 6015.  Yes, we have always used them in the labs where I have worked.
I thought there was a derate curve for the older probes when running them dry.   Personally, if I didn't work with these higher voltages, I would run them dry.
The later probed we have are filled with a solid, so no maintenance.   I have it's little brother at home that also does not use freon.  I had pushed that probe past the limits several times but eventually made that wideband HV probe to work at these higher voltages.
Sounds like your interest in HV far exceeds any interest in the thread topic.  You may want to consider starting a new thread in the test equipment area to discuss restoring your probe as I doubt many people are following this particular thread.   You may find a people willing to help out once you make it visible to them.
« Reply #449 on: June 10, 2023, 04:30:20 pm »
Shown with a Narda 3095 installed on my extender.  Added some support for the amplifier and also made a section of semi-ridged to connect the coupler's input port.  I have not yet decided on adding a relay.
The coupler made a big improvement.  Plots showing the data I had previously collected with the extender compared with the update.  I used the same homemade standards and Agilent X11644A coefficients  to calibrate the VNA to 12.1GHz.   I had only swept to 12GHz before as the performance was so poor.   The mixers only support an IF of 4GHz and as the range is increased beyond 12.1, the performance starts to degrade quickly.
Decided to roll the dice on used Amphenol connectors rather then trying the Chinese ones.  I was a bit worried they would have just been a waste of time.
