Still using the symmetry mode but moving both ends of the gap to avoid the diagonals, I had hoped some of the data would make a little more sense. I also thought it may reduce the memory requirements and speed up the simulation.
Quote from: joeqsmith on August 04, 2021, 09:49:39 pmStill using the symmetry mode but moving both ends of the gap to avoid the diagonals, I had hoped some of the data would make a little more sense. I also thought it may reduce the memory requirements and speed up the simulation. Did you come up with anything conclusive since?Work went crazy in the past couple of weeks, I didn't have any time, but I'm still curious to see a comparison to measurements.
