Author Topic: E/H field to RF level in coaxial cable conversion (DON'T BOTHER)  (Read 714 times)
Offline Neomys SapiensTopic starter
Does someone have the law or conversion formula ready which can be used to determine which level of interference in a shielded/coaxial transmission line will result from an external field as it appears in radiated susceptibility tests? Of course, the screen attenuation goes into it, but how to calculate that?
« Last Edit: April 20, 2021, 10:55:55 pm by Neomys Sapiens »
Offline radiolistener
  • Country: ua
Re: E/H field to RF level in coaxial cable conversion
« Reply #1 on: April 20, 2021, 10:36:39 pm »
At a glance you can use classic shielding attenuation formulas and calculate it from the coax cable insulation size (between braid and the center wire), braid conductor thickness and magnetic permeability. But I think the things may be a bit complicated, because the result will depends on cable orientation against field polarization and direction vector.
You will get at least 3 attenuation values:
- for plane wave far field (when RFI source is at distance more than lambda/2)
- for E near field component (electrical field)
- for H near field component (magnetic field)
In short, more thick coax cable with more thick braid provide you with better shielding.
« Last Edit: April 20, 2021, 10:46:57 pm by radiolistener »
Re: E/H field to RF level in coaxial cable conversion (DON'T BOTHER)
« Reply #2 on: April 20, 2021, 10:58:45 pm »
Sorry - such is the kind of stupidity resulting from a frantic workload. Basically, I have to treat the center conductor as an antenna. Orientation, length, diameter etc - with the screen attenuation in front.
