Ok, this one has been a long time coming (as you can see if you look at the dates on these photos). A while back, I got the chance to explore a Rohde & Schwarz FSL spectrum analyzer (with an impressively wide range of 9 kHz - 3 Ghz) that wouldn't turn on.
![](https://live.staticflickr.com/65535/49660550941_504867f28f_z.jpg)
Here's the top and bottom sides, with the cover removed:
![](https://live.staticflickr.com/65535/49660833777_058ae2b1bc_z.jpg)
The top side has the CPU board, plugged into the main board, with the power supply at the back end.
![](https://live.staticflickr.com/65535/49660834132_b2241d8743_z.jpg)
The bottom side normally has the RF module sitting up front (I had removed it here), and a large open space for a battery option at the back. You can see that the RF module plugs into an SMA connector from one end (which goes straight to the front-panel input connector via some rigid coax) and a ribbon cable to the main board at the other end.
![](https://live.staticflickr.com/65535/49660552031_076cc9c480_z.jpg)
![](https://live.staticflickr.com/65535/49660010363_1f2d2f0468_z.jpg)
The CPU board is likely based on an Intel processor, definitely has an Intel chipset, and runs an embedded Windows XP (which honestly made the UI a pain to deal with) from a CompactFlash card.
![](https://live.staticflickr.com/65535/49660550781_db9b73da53_z.jpg)
The main board seems to have all the "in between" functions: interfaces to the front-panel display and buttons, power supplies, the 10 Mhz reference clock, and data acquisition connecting the RF module to the CPU. Sadly I couldn't take off the CPU board to get a better look at the main board - the CPU-side connector was an unsoldered press-fit type, which when I started gently pulling on it gave signs that it would rather pull out of the CPU board than de-mate from the main board's connector. Didn't want to turn what could be just a power supply issue into a much bigger/more expensive issue, so I stopped there.
Anyways, the thing we really wanted to see was the RF module!
![](https://live.staticflickr.com/65535/49660550186_a66a7403bf_z.jpg)
![](https://live.staticflickr.com/65535/49660825267_7aa6ac56c7_z.jpg)
![](https://live.staticflickr.com/65535/49660824747_e2d41fd903_z.jpg)
Here's the circuitry in all its naked glory:
![](https://live.staticflickr.com/65535/49660543026_224faa8db1_c.jpg)
![](https://live.staticflickr.com/65535/49660008643_132ba0ba31_c.jpg)
I haven't been able so far to figure out everything that's going on here, especially because I'm not an expert in microwave electronics. In general, I'd expect a modern spectrum analyzer to have some input attenuators for range selection/protection, maybe some different selectable band filters, one or two IFs worth of frequency-synthesizer LOs / mixers / filters / amplifiers, then direct digitization of the last IF.
Well, we can see what looks like some selectable attenuators on the input here, with a relay and some
Peregrine PE42551 RF switches:
![](https://live.staticflickr.com/65535/49660539466_83c9d5acb4_z.jpg)
Relay seems to select whether the input goes into the attenuator or the bypass path, and the ICs select whether the output is connected to the attenuator, the bypass path, or a mysterious path which goes to the other side of the board, through an IC I can't identify, and then into the Inner Mysteries of the inner layers (doesn't come out the top again):
![](https://live.staticflickr.com/65535/49660826492_582d1b0092_z.jpg)
There's also a nice distributed-element filter connected to an unpopulated connector, probably for one of the options we didn't buy like a tracking generator.
The IF (or something at least) definitely gets digitized at the end: there's an
LTC2206-14 14-bit 80Msps ADC that looks like it's fed by a single-ended-to-differential converter in the SOT-23-5 package, with its outputs going through buffers to the ribbon cable back to the main board of the instrument.
![](https://live.staticflickr.com/65535/49660548456_2cbf7fc33f_z.jpg)
What's in between the input attenuator and the ADC though? That's the tricky part...
The LO (at least one of them?) is at least surprisingly easy to spot. There's a VCO, based on (unsurprisingly) a single-transistor LC oscillator with a group of 8 varactors for tuning. It's nice and easy to figure out the connections because they're all directly on the top layer:
![](https://live.staticflickr.com/65535/49660823137_4862b46606_z.jpg)
There's also some power filtering and linear regulators to the right of the VCO (LT1964 low-noise LDOs, to be specific).
To the left of the VCO is the rest of the frequency synthesizer:
![](https://live.staticflickr.com/65535/49660540976_13cef5d91b_z.jpg)
There's an
HMC439 phase detector at the left, meant as part of a "build your own PLL" sort of affair. It likely gets its input through the custom-looking "PD_DIV2" chip at the right, which is probably a programmable divider. The HMC439 feeds a pair of tuning currents back to the VCO, and if you look back at the VCO shot, you can see a pair of signals coming up from vias together and going into the 5534 dual op-amp just above the VCO, which should turn them into a tuning voltage for the varactors.
A transformer just below the HMC439 seems to turn the divider's single-ended (I mean, uh, unbalanced) output into a differential (I mean, uh, balanced) input that it needs.
There's a bit of other weirdness just above the programmable divider that I couldn't figure out. The VCO's transistor (and all the others marked "N9" seem to be the
BFG540W.
After this though it all gets murky as far as I'm concerned:
There's one section with a bunch of tuning-fork-looking power dividers at the left, and 3 almost-identical sections which could be for different frequency ranges?
![](https://live.staticflickr.com/65535/49660821137_a93fd2ea95_z.jpg)
There's some filter blocks:
![](https://live.staticflickr.com/65535/49660542581_a438320d6f_z.jpg)
There's this weird shit over here, which seems to be transmitting something through a patch antenna (?) and picking it up with a slot antenna (
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
) on the other side?
![](https://live.staticflickr.com/65535/49660008073_c10d6a43db_z.jpg)
(Look at the right-hand edge)
There's two back-to-back power splitters/combiners in a configuration I don't understand at all (see top-left):
![](https://live.staticflickr.com/65535/49660005228_4c24d4a341_z.jpg)
There's even some mystery Atmel parts, with custom-looking part numbers that don't turn up in any search results:
![](https://live.staticflickr.com/65535/49660547531_e5d0edd9df_z.jpg)
Anyways, if anyone feels like explaining what all the in-between pieces actually are, go crazy, here's the link to the full photo album of board shots:
https://flic.kr/s/aHsmLYteisJust let me know what you find.
