I picked up a microwave relay at ham swap to build an antenna switch.
The label reads:
DYNATECH SCM 50667
MOD D1-418D58
The coil config is rather interesting:
- 3 wire driver connection, with common and 1 and 2
- The DC resistance across any pins shows open
- When applying 24V to comm and 1 or 2 it clicks and latches
- Polarity matters: Com is +, terminal 1 or 2 needs to be - to switch
What is the standard driver circuit for this kind of relay, current and timing wise?
