Author Topic: Drake SPR-4 Shortwave Receiver  (Read 10843 times)
xrunner, miniant and 3 Guests are viewing this topic.
Online xrunnerTopic starter
  • hp>Agilent>Keysight>???
Re: Drake SPR-4 Shortwave Receiver
« Reply #50 on: June 20, 2019, 01:28:42 pm »
So here she is - the fully restored Drake SPR-4 in it's rightful place on my radio desk.
Now, back to Ebay!  :-+
Online Kosmic
« Reply #51 on: June 21, 2019, 12:57:23 am »
Good job, look really good  :-+
« Reply #52 on: June 21, 2019, 08:03:37 am »
Indeed. Excellent work  :-+
« Reply #53 on: June 21, 2019, 08:44:52 am »
Looks really good there, what's next?
Sent from my POT-LX1 using Tapatalk
« Reply #54 on: June 21, 2019, 01:26:00 pm »
Thanks a lot guys.  :)
I found an MFE3007 dual-gate MOSFET the SPR-4 uses for the rf amplifier transistor on Ebay (NOS) for cheap, so I got it in reserve in case needed someday.
What's next? As far as a project not sure. However, 6 meters is really alive in the day now so I might just use what I have for a while LOL. Just this week I worked three new DX entities on 6m - Belize, Costa Rica, and St. Martin using the homebrew beam. We had a high windstorm last week and it looked like one element of the beam was bent by the wind but it was only torqued at the screw joint. I got up there and was able to tap it back with a garden tool. After the season I'll take it down for the winter and look at making some of my own mechanical improvements. It needs to hold the elements a bit better. I see the 3D printer involved in some way. Some of the fittings are already made by a 3D printer my friend's friend made for this project. He made them out of PETG which is tougher than PLA.
I designed my own style of antenna end-insulator right after I got the 3D printer. I don't like most of the types you can buy. I want my antenna wire to pull straight out of the insulator and not wrap around and/or tie in knots. I installed them this spring on two different fan dipoles. Two are printed in gray and two in white. The material is PLA. I want to see how they hold up after the blazing heat of the summer. Some say they will get soft and stretch. That is what I will find out. So far, they look just fine. If anyone wants the CAD for the insulator to use or mod let me know. Hmmm ... might ask DAVE if he can add .stl as a file attachment type (or could be zipped I guess).
« Reply #55 on: September 21, 2023, 11:11:04 am »
I received a PM regarding the file I used to print the dial numbers. I will attach the Open Office file here for anyone who might need it. The font and spacing should be OK. Edit the file with your specific band details. But you must use clear adhesive "paper" to print it.
Online carlos2007
« Reply #56 on: Today at 01:36:08 pm »
Hello,
Interesting post, I am going to align my SPR4 but I see that the OP only made the 50 Khz  and 5645 khz if alignment. What about the preselector and injection alignment (mixers circuits) , local oscillator.....?
I would be very pleased if somebody could explain the rest of steps since is not very clear.
I have came across with a website that explain the rf amplifier and mixers more in detail:
http://www.dashdist.com/1u2u/SPR-4/improve/improve.php
I attach an old invoice that came with the SPR-4 I have purchased
Offline Smoky
« Reply #57 on: Today at 03:04:02 pm »
That's a cool looking radio. Great job Xrunner :-+
« Reply #58 on: Today at 04:12:03 pm »
Thanks.  :-+
What about the preselector and injection alighment do you want to know? It's been 5 years but I only made posts about the steps I thought needed explaining if I did it differently from the service manual, or that I thought needed more explanation. Just because I didn't post about every step doesn't mean I didn't do them.
The only problem I ran into was that I didn't have several of the accessory xtals, probably because they weren't available.
Online carlos2007
« Reply #59 on: Today at 07:34:51 pm »
Thanks for the prompt answer. Is the rest of the alignment difficult? Did you find any remarkable problem in the rest of alignment?
 By the way I am a bit confused about  the 50 khz LF filter alignment there are four transformers, T11 to T14, are adjustable but they have a small spring and I am not familiar with this type of adjustment.
 How is the method for aligning this type of slug, do I have to pull out the spring or just turn it? Spring or white and red discs need to be  hold? Photo is attached.
 Regards.
