Thanks for the prompt answer. Is the rest of the alignment difficult? Did you find any remarkable problem in the rest of alignment?
Not that I can remember, but it was 5 years ago.
By the way I am a bit confused about the 50 khz LF filter alignment there are four transformers, T11 to T14, are adjustable but they have a small spring and I am not familiar with this type of adjustment.
How is the method for aligning this type of slug, do I have to pull out the spring or just turn it? Spring or white and red discs need to be hold?
Well you caught me off-guard with that question. I couldn't remember pulling any springs so I took mine apart. OK, what these are is a coil of very hard wire that can be
turned not pulled. Sort of a miniature version of the coil that goes into your sewer when they snake it. On the end the coil is flattened so that you can use a tuning wand with a slot on one end. You have to adjust these with the case
ON from the back of the receiver and without using metal tools. You might have to buy a set of plastic tuning wands if you don't have any ... but ...
It looks to me from your pic that a gorilla has got hold of yours and mucked around with the end of that coil, perhaps twisting it or trying to turn it with a pair of pliers or something. I think they ruined the flattened part so a tuning tool might not work now. I'd have to think about what to do if the end is ruined, maybe some readers here will have an idea.
