I'm not quite following your question, does Sxyk represent the lines, or the thing you are trying to measure? Is S11 the impedance you want to see? and is it you want to see the effects of the lines on S11 (that is, emulate lines in AWR to see how S11 rotates and presents a different S11m?), or you want to see S11 after de-embedding the lines (which are represented by Sxyk where k is indexing different lines?) ? A better problem statement would be needed to give a better answer.
