in my view radiolistner gets fixated on an issue
In my point of view, m3vuv and vinlove are just trolls. And I will not be surprised if those are two clones of the same people whose third clone was previously banned
Just because:
1) trying to insulting and discuss personalities instead of technical subject
2) ignoring request to provide measurements, for example:
I don't have time to make screen shots of nanoVNA for this thread.
I don't need look at Smith Charts and make Screen Shots....
That's pretty clean trolling indicator.
3) talking "believe/don't believe" and trying to ignore technical explanation with absurd arguing, such as "I have QSO so antenna cannot have problem", etc.
4) wrote stupid and provocative things, for example:
Tell me, what you, yourself understand about the common mode current. Have you seen it? Have you touched or smelt it?
5) trying to switch subject of topic:
How does that help you making some good DX contacts or pleasurable CW QSOs on HF? Do you even have radio licence to transmit?
There is nothing to discuss in this thread anymore, because most possible root of cause already provided - unbalanced antenna with different counterpoise configuration for SWR and for VNA cases.
There are possible a lot of other possible issues, for example incorrect VNA calibration. But topic starter don't wan't to provide measurements to check it and trying to switch to discuss personalities. So, there is no sense for further discussion.
