OMG, does it really cost that much?
(Need to check prices around here!)
No way could/would I ever buy pure copper for that much. Copper piping (which I already have some of) is probably significantly cheaper, but the two pieces of pipe I have - its been years since I bought it. Could have gone up, I suppose.
I find it makes a decent RF case, so have used very small pieces of it in projects.
As you can see there is a good reason that galvanized or copper plated steel rods are popular.
Copper plated lasts 30..50 years, galvanized as you say around 15 years (10-20).
Not a big deal to drive a new one in 15 years.
Single rod is OK only for small shack that does not need lightning rod. Even 2-bedroom house needs at least 4 ground rods - one for each lightning rod and at least two or even three for mains power earthing.
Look how much >= 10' rods are needed for wind turbine.
The only reason to use this rather than the steel would be soil conditions which would remove the plating either by abrasion while driving or by chemical reaction with acidic ground water.
Right. Stainless steel rods for salty ground water sites as well. If you own small island in the ocean - use stainless steel. If you are crazy enough purist to buy pure copper grounding rods for 400$ each, make sure nobody knows it, otherwise they will be stolen. Imagine - somebody steals copper of your earthing during bad weather and lightning strikes, then his relatives sue you for negligence
Nobody around where I live has lightning rods on their houses. In my memory I have only seen obvious lightning rods on very large houses with lots of lightning exposure. (houses that stick out on a ridge line and present an obvious target for lightning)
Because of CATV and satellite services, few houses in my area now have visible antennas of any kind that stick up. Back in the day when people had TV antennas it was common practice to ground the mast using a thick wire, (but not that thick) to a ground rod.
I don't currently have any antennas mounted anywhere (high or not). Its always been my plan to ground them when I did, though. In a cost effective manner.
The place I live would probably qualify as a little shack.
How would I be able to tell how successful my grounding efforts were?
