Author Topic: Common gate wideband RF amplifiers  (Read 14360 times)
Offline KE5FX
    • KE5FX.COM
Re: Common gate wideband RF amplifiers
« Reply #25 on: December 03, 2021, 08:40:59 pm »
See below for a VNA derived plot of K for a jellybean 2N3904 in common emitter configuration at 10Vce and 10mA Ic. The s-parameter data extracted from my VNA shows that self oscillation of the 2N3904 is possible at over 1GHz as K is <1 to beyond 1GHz.
These are nifty plots.  What generates them?  They're just based on the gain and phase of S21, nothing else?  I'm thinking I need another button on my VNA GPIB app.
Online G0HZU
« Reply #26 on: December 03, 2021, 10:01:20 pm »
They are generated using the last version of the old Eagleware Genesys RF simulator before it was sold to Agilent/Keysight in 2005. This old software allows some powerful post processing of full 2 port s-parameter data from a VNA. However, the plot below is just of resistance Rs looking into the resonator and the phase angle of zin1.
In this case I measured a 2N3904 at 10Vce and 10mA Ic in a VNA test fixture using bias tees and then imported the s11 s21 s12 s22 model into the simulator and used it in a negative resistance oscillator circuit. In this simulation I was scraping the last of the negative resistance the 2N3904 could generate at just over 1GHz. The VNA predicts the raw 2N3904 can actually generate negative resistance all the way up to 1200MHz at 10Vce 10mA Ic but this would require lossless resonator and feedback components in the oscillator.
See below for the negative resistance plot looking back into the resonator (at resonance) and the spectrum analyser plot of an actual 2N3904 oscillator built using the same circuit as the simulation. This kind of validates the s2p data from the VNA. It was a surprise that the 2N3904 could oscillate this high up in frequency! With today's fast BJTs I've used this technique for oscillator analysis all the way up to 16GHz with good results.
« Last Edit: December 03, 2021, 10:04:58 pm by G0HZU »
Online G0HZU
« Reply #27 on: December 03, 2021, 10:27:20 pm »
Here's the same VNA model data analysed and post processed in Genesys to show current gain for the 2N3904 at 10V 10mA. You can see in the right hand graph that Ft is predicted at 100MHz to be 314 because the 100MHz marker shows a current gain of just 3.14 at 100MHz. 100 x 3.14 = a predicted Ft of 314MHz.
The green trace on the graph on the left shows the classic 6dB/octave slope in current gain and it does cross zero at about 300MHz and this matches the Fairchild datasheet value for Ft quite well at 10Vce and 10mA.
« Last Edit: December 03, 2021, 10:30:51 pm by G0HZU »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #28 on: December 04, 2021, 01:18:48 am »
What's the configuration look like, for the 1GHz oscillator?
Seven Transistor Labs, LLC
Online G0HZU
« Reply #29 on: December 04, 2021, 03:37:54 pm »
The oscillator doesn't really have a classic description as such. If you look back at reply #20 the K curve for the 2N3904 dips below 1 to just past 1GHz. Because this is a leaded part (non-SMD) there will inevitably be a few nH of inductance in each leg of the transistor. This is partly what makes it prone to instability.
All I did to complete the oscillator was to plot the instability circles in Genesys at 1GHz. Where the circles cross into the smith chart tells me what capacitive or inductive reactance to put at the collector and the base to make the system unstable at 1GHz. All I had to do then was crudely bias the BJT at 10Vce and 10mA Ic and then add the required reactances at the collector and the base legs. Then power it up and sniff the circuit with a small E field probe and a spectrum analyser to see it oscillating at just over 1GHz.
I used the same procedure for the 1500MHz MMBFJ310 oscillator. The main goal in both cases was to explore the highest frequency that the VNA data suggested the device could go unstable (at that bias point). I think If I used lower ESR parts for the reactances I could have got closer to 1200MHz for the 2N3904 oscillator and maybe 1600MHz for the JFET oscillator. It is very rewarding to see the circuit oscillate exactly where the VNA predicts it will and it does help prove that my VNA setup can produce decent s2p models up above 1GHz.
« Last Edit: December 04, 2021, 03:45:09 pm by G0HZU »
Offline David Hess
  • DavidH
« Reply #30 on: December 04, 2021, 03:45:07 pm »
There is or was enough variation in 2N3904 Ft that Tektronix used to grade them from a specific vendor for high Ft in some applications.
Online G0HZU
« Reply #31 on: December 04, 2021, 03:58:35 pm »
Yes, there's bound to be some spread in performance even within the same batch of transistors. I used a 2N3904 that I purchased from Farnell here in the UK. See below for the bag and Farnell part number. If I tested all 100 devices in the bag there would be some variation in performance in extreme tests like this.
I wouldn't recommend experimenting with 2N3904 devices purchased on ebay or from small time vendors as there is a huge risk that the part is fake or is something else rebadged as a 2N3904.
I think what is more relevant to this thread is that there will be a significant spread in performance for J310 JFETs. I picked out a MMBFJ310 part (also purchased from Farnell) that produced the expected 12mmho gm at 10Vds and 10mA Id to match the datasheet. Within that bag of 100 JFETs there will probably be a few devices that can produce sufficient gm to get close to the performance shown in the HR magazine.
I might have a go at making the version with the 9:1 transformer and a pair of MMBFJ310 JFETs in parallel. Even if I only end up getting 10dB gain it would still be an interesting amplifier design to play with.
Online G0HZU
« Reply #32 on: December 04, 2021, 10:19:12 pm »
I had a rummage in my s2p library of old autotransformer models and found an s2p file of a basic 9:1 autotransformer wound on a 61 material toroid. This was not a great transformer when it was tested as you can see in the second plot below.
However, I tried simulating it along with a pair of MMBFJ310 JFETs in parallel. The performance was much better than I was expecting. It managed just over 10dB gain up to almost 75MHz and the results were close to that of the HR magazine for the amplifier in figure 5 of the magazine article.
Note that I did struggle a bit with the 1.4uH inductor. Up at 75MHz the behaviour of this inductor will depend on the way it is designed and wound and also on its Q up at 75MHz. I found I had to put a 4k7 damping resistor across the inductor model to prevent excessive peaking up at 75MHz.
See the simulation plots below. Of all the amplifiers I've looked at so far this one is the most interesting. I think it deserves a better transformer than the autotransformer model I used in the simulation. This autotransformer was not wound the same way as the 9:1 transformer in figure 5 of the HR magazine. I didn't use three twisted wires. I just used a classic tapped autotransformer with 1 main winding wire tapped a third of the way along.
« Last Edit: December 04, 2021, 10:27:01 pm by G0HZU »
Offline David Hess
  • DavidH
« Reply #33 on: December 04, 2021, 10:34:57 pm »
Just checked it again and they were grading 2N3906s for rb'Cc < 50 picoseconds which is an Ft of 600 MHz seems awfully far from the 2N3906's specified 250 MHz.  I guess rb'Cc is base transit time?
Online G0HZU
« Reply #34 on: December 04, 2021, 10:55:26 pm »
I've not tested many PNP BJTs like the 2N3906 so I can't really comment other than to ask what operating point are they testing at?
I can see a significant variation in Ft for the same BJT in the same test fixture when tested at a lower operating point. See below for the very same 2N3904 tested at just 0.5mA and 3Vce. The Ft drops from 300MHz to just 133MHz.
I usually measure s-parameters for a BJT or JFET across 3V, 5V, 7V, 10V, 12V and 15V and sometimes 20V. I also do this across 500uA, 1mA, 2mA, 3mA, 5mA ,10mA and 15mA for each voltage. Usually I do a log sweep across 300kHz to 2GHz. It's important to turn the VNA source power really low to prevent compression problems. I also use a carefully corrected test fixture that sets the reference plane very accurately at the device pins. I use the built in 'fixture simulator' feature in a 4 port E5071 VNA for this and I use a N4431B 4 port Ecal to calibrate everything.
https://www.keysight.com/gb/en/product/N4431B/rf-electronic-calibration-module-ecal-9-khz-13-5-ghz-4-port.html
I can try and create a classic VCCS transistor model to try and 'fit' the s-parameter data but I'd have to guess Rbb and see if it fits the s-parameter data at a chosen operating point.
Offline David Hess
  • DavidH
« Reply #35 on: December 04, 2021, 11:34:31 pm »
The test had to have been at 20 volts and 10 milliamps because that is what the Ft (min) was specified at, and the real circuits operated at that kind of current.  They gave the grading criteria but no details on exactly what the test was.
I can probably find the exact circuit the transistors were used in if you think it would be helpful; I think it was a 100 MHz PNP cascode so common base which is why I mentioned it here.
There is an additional notation of NF being 6dB which made me wonder if Tektronix measured the noise figure to get an estimate of the Rbb (1), but the 250 MHz 2N3906 is marked as a 4dB noise figure which is the opposite of what I would expect, so I do not think they were measuring noise figure to calculate Rbb to get to rb'Cc to get to Ft, and they listed rb'Cc as the grading criteria and not Ft.
(1) That is the kind of weird thing I would do, but only after verifying that there was a real correspondence between them.  I never found a useful explanation about how to measure base transit time except estimating from Ft.
Offline KE5FX
    • KE5FX.COM
« Reply #36 on: December 05, 2021, 08:24:19 am »
The inductor can be dispensed with if you are interested in HF.  It has no effect on NF or anything else besides VHF gain (and I suppose S22.)
I tried the figure-5 amp just now with a CPH6904 (dual CPH3910) at its max Id of 40 mA in place of the E430.  It worked fine.  Best performance I saw was 12.7 dB of gain at 50 MHz with NF in the 1.5 dB range.  At currents less than 40 mA, the VHF gain fell off, the HF gain came up, and the NF was largely unaffected.  The input impedance varied quite a bit with Id.
I didn't see any peaking, but I also didn't try any inductors other than the 910 nH / ADT9-1T combination in green.
Reverse isolation is more like 30 dB rather than 36 dB predicted by the article, but I didn't characterize it versus Id.  I also didn't check IP1dB but it was +6 dBm with a single CPH3910 configured for 10 dB of gain at 10 mA, so likely better now.
Of course 40 mA at +/- 12V is almost a watt, so you wouldn't normally run the part this hard.  (Edit: there is also some saturation in the Mini-Circuits transformer at this current level, so AC-coupling the transformer buys another dB or so of gain.  NF is unaffected as is the oddly-poor LF performance.)
Good part.  Everybody buy lots of them, so they keep making them.
« Last Edit: December 05, 2021, 08:47:15 am by KE5FX »
Offline biastee
  • Country: my
    • 9W2LC
« Reply #37 on: December 05, 2021, 02:00:58 pm »
Yes, it's the introduction of some inductance at the gate connection that can lead to instability up at UHF.
The second plot shows K when just 4mm of leg inductance is added at the gate and this simulates what you might see from a non-SMD part. You can see that K goes below 1 over much of VHF and UHF. This opens the door to instability. This is just at 10mA Id. It would be a bit worse at 18mA ID and even worse again if two were placed in parallel. This should show that this type of amplifier is really prone to instability up at UHF unless care is take to ensure a short gate connection. If you use the T0 plastic J310 then you really do have to try to cut the gate leg 'really' short and even then I suspect it wont achieve a K over 1 at UHF. However it will help reduce the chance of instability.
I share G0HZU concern over common gate's sensitivity to ground inductance. In a 435 MHz amp, a dual gate mosfet (which is a cascode of CS & CG) BF988 / 998 developed an unintended gain peak at ~1.6 GHz (black trace in gain graph) when the gate 2's bypass capacitor (C4 in the attached photo) is located 5 mm away from the transistor package. Replacing C4 with a 0805 chip at ~1mm away, eliminated the gain peak (blue trace in gain graph).
1341434-0
However the noise figure was 2.9dB at 30MHz and I suspect this would dip below 2.5dB (to agree with the HR magazine article) if I could cherry pick a couple of matched J310 devices with higher Idss.
Noise matching the J310 at 98 MHz resulted in 0.4 dB NF whereas conjugate matching achieved 3 dB NF (attached image)
« Last Edit: December 05, 2021, 02:29:17 pm by biastee »
Online G0HZU
« Reply #38 on: December 06, 2021, 12:10:12 am »
Some good results there from KE5FX and biastee! I'll have to check out the CPH6904 and CPH3910 JFETs on the VNA. They do seem to have a very high transconductance compared to the J310.
I don't think I've ever managed to get a NF below about 1.5dB with a U310/J310 at VHF but usually I aim for a compromise between input match and noise figure.
Online G0HZU
« Reply #39 on: December 18, 2021, 08:47:42 pm »
I had some free time today and managed to take a suite of s-parameters for the CPH3910 JFET at various operating points.
I haven't built any amplifiers but I did try to marry the s2p file up with various transformer models I have here.
One interesting result was with an S2p model of a 49:1 transformer with some compensation. The simulation predicts about 14dB gain across 1 to 14MHz with fairly good input and output match across this range. This was with a pair of CPH3910 JFETs in parallel each biased at 10V and 15mA.
I'm not sure what practical application this amp has but it was interesting to see the result. The gate inductance needs to be sub 1nH to maintain K above 1 up at UHF with this simulation.
« Last Edit: December 18, 2021, 09:32:19 pm by G0HZU »
Online G0HZU
« Reply #40 on: December 18, 2021, 09:45:26 pm »
Based on my s-parameter measurements here's a plot of GMAX and K for a single CPH3910 at 10Vds and 15mA. You can see that K dips below 1 even with a directly grounded gate pin. If the inductance of the gate connection goes up to just 1nH see the second plot for what happens to K up at UHF. I think great care is needed with this device to manage stability. It looks like this device can oscillate up above 2GHz.
Offline Gerhard_dk4xp
« Reply #41 on: December 18, 2021, 10:51:05 pm »
Now that you have measured the s-parameters, would you share them?
It would remove the need for me to do that over the holidays.
I found that an array of 16 ON CPH3910 oscillates happily at 650 MHz,
working common source into a bipolar cascode. And every gate has a
different AC voltage, even though they are connected by relatively short
traces; 2.4 GHz scope including active probe
(16 pcs. in par for voltage noise reasons)
The parallel lines are an efficient  coupler. It took a ferrite bead in each
gate and a 0603 cap at each drain to kill that. ~2nF in total until it began
to impair my 2 MHz baseband bandwidth. (cascode is low impedance)
I admit it could take less, but I was fed up with oscillations.
BTW NSVJ3910 is quite repeatable. Cannot be compared to IF3601 etc.
« Last Edit: December 18, 2021, 11:56:13 pm by Gerhard_dk4xp »
Online G0HZU
« Reply #42 on: December 19, 2021, 11:31:30 am »
Hi Gerhard
I only have CPH3910 s-parameters in common gate so far. If you let me know the operating point of your CHP3910 in common source I can measure a set of  s-parameters for you. Note that my test setup only supports up to about 15mA current. I should be able to do up to 20V at 12mA or maybe 15V 15mA but that is about the limit. I do measure the dc operating point very accurately, usually to <0.5% using a pair of DMMs. What is the BJT you use in the cascode and what is the dc operating point?
« Reply #43 on: December 19, 2021, 12:37:22 pm »
45 mA/ 3V for 16 FETs. The Cascode is folded, with BC860.
I will probably unfold it since I need more than 2+2 Li batteries anyway.
Bandwidth is only 1Hz to 2 MHz but the 3910  is much faster.
Don't measure it when you don't need it yourself. My ZVB8 has built-in
bias-tees, so it is no effort with the test circuit.
73, Gerhard
Online G0HZU
« Reply #44 on: December 20, 2021, 07:06:58 pm »
OK thanks. 45mA is way too much for my test fixture so probably best you measure it with the ZVB8.
I had a go at doing a practical LNA design using the CPH3910 s-parameters today. The aim was to make a low noise preamp for the 88-108MHz band. See below for the simulation based on the s-parameters at 10Vds and 10mA. The result was quite good in terms of passband gain and port match across 88-108MHz. I'd expect it to achieve a noise figure of about 3dB but with an L match at the input this could probably achieve 2dB noise figure with a bit of input mismatch.
I'd expect the OIP3 to be better than +20dBm so this would be a cheap LNA for the 88-108MHz FM band with 13dB gain and fairly good noise and signal handling performance from just 10mA.
Online G0HZU
« Reply #45 on: December 20, 2021, 11:15:42 pm »
I just built the VHF FM LNA circuit this evening but I tweaked it for 50 ohm ports rather than the expected 75 ohm. This makes it easier for me to measure as all my test gear here has 50 ohm ports.
See below for the simulation (based on my s-parameter data of the CPH3910 and some simple circuit models for the R, L and C components) and this is compared to a measurement of the built circuit using the VNA. I think if I had measured the inductors on the VNA and I had modelled the circuit strays better in the simulation the agreement would have been closer. Even so, there will be some spread due to component tolerances.
This does at least show that I can measure s-parameters of SMD components quite well!
I'll have a go at measuring the noise figure and the signal handling tomorrow.
Offline KE5FX
    • KE5FX.COM
« Reply #46 on: December 21, 2021, 12:47:54 am »
Nice.  That's a tight match!
« Reply #47 on: December 21, 2021, 01:56:59 am »
The 45 mA is for 16 transistors, not for one. In a single FET, the voltage
noise improves only with the 4th root of drain current, so there is no point
to overdo this.
The measurement of Id over Vgs was really to make sure that the 3910 are
close enough to put them simply in parallel. The Interfet IF3601 stray so much
that with a given Vg some may be fully open while others still are closed.
The closed ones would add capacitance while doing no contribution to
voltage noise performance.
For the 3910, it is OK.
I'd like to see if I can extract the parasitics of my layout with ElectroMagnetics
to predict the instability. Probably a non-starter, for me being just a beginner
with that.
The common gate JFETS with Zin= 50 Ohms remind me of the ring mixer
terminations proposed by DJ7VY and Ulrich Rohde some 35 years ago.
« Last Edit: December 21, 2021, 02:05:17 am by Gerhard_dk4xp »
Online G0HZU
« Reply #48 on: December 21, 2021, 02:32:04 am »
Hi Gerhard, if you can confirm that the Id is 45/16 = 2.8125mA and the Vds is 3V (as in the dc voltage measured across the drain and source rather than just the voltage of a 3V power supply) then I can have a go at measuring the s-parameters in common source. My CPH3910 devices are made by On Semi and purchased at Farnell so should be genuine parts.
Thanks! I'm lucky to have some nice test gear here so I'll try and measure the noise figure tomorrow. My noise figure setup is about as good as it gets for hot/cold Y factor hardware and I think the overall uncertainty is very low. I think the noise figure will be a bit worse when tested at 50R. I'll also try measuring the NF with a simple L match to step up the source to 75R. I'm expecting to see about a 2dB noise figure with the L match.
I did quickly measure the OIP3 and it was a fairly consistent +20dBm across the whole band. Increasing the supply voltage slightly improved it to just over +20dBm.
Online coppercone2
« Reply #49 on: December 23, 2021, 03:34:14 am »
I would have said that a 2 to 3 dB noise figure is pretty good for a commonly available part and simple circuit, but at HF and maybe 6 meters, that is more than enough performance because of high levels of background noise.
I would like to see more about how to produce high IP3 and compression for an low noise LNA, but the measured performance is pretty good, although power consumption is high as well.  The designs I remember use a differential two transistor common-base amplifier.
A lot can be learned from old articles like this.
I keep hearing about HF and background noise (run into a limit), but what happens to lunar or spaced based HF transmitters?
I thought maybe there is a good reason to investigate this for hobbyists interested in some kind of cubesat etc.
« Last Edit: December 23, 2021, 03:37:41 am by coppercone2 »
