Author Topic: LMX2820 PLL board on eBay  (Read 6796 times)
Offline rfdave#gmail.com
Re: LMX2820 PLL board on eBay
« Reply #1 on: March 07, 2024, 02:30:42 am »
It's certainly not going to be any better than the datasheet performance, so that would put a floor on the expected performance. The OCXO will only improve performance at BW inside the loop filter BW. The loop filter is external, so you can tweak that somewhat.
Offline Aiy
« Reply #2 on: March 09, 2024, 05:14:05 pm »
It certainly is an interesting board.
I didn't know they were this cheap.
I'm probably gonna get myself one for experimentation
good find!
Best regards
Offline jayk
« Reply #3 on: March 27, 2024, 09:27:58 pm »
Definitely cheap, but that's at most a TCXO (not an OCXO) and it would have been nice if they'd matched the length of both differential outputs.
Offline Verticon
« Reply #4 on: April 01, 2024, 11:38:14 am »
these boards are damn cheap. The price at Mouser is roughly 115 EUR (quantity 1) for the LMX chip only. Therefore I wonder if they use low quality chips. It also seems that they use simple FR4 material which could explain the level decrease at the high frequency end.
Best regards
