Anyway from what I see in your images you have a perturbation source nearby your house or in your region. If you want to be sure just scan the band with other scanner or ask someone to do it
If you read it carefully, the source of these spurs is MSi.SDR itself and it was tested with open input (nothing connected to it). There is no such interference in the house, you can see that RTLSDRv3 receiver don't show it. The same there is no such spurs on other receivers. I have no idea where you see "perturbation source nearby your house", because these spurs and beats are present on MSi.SDR only and it's frequency depends on LO setting.
or you just had some bad luck and get a broken sdr radio.
this is possible, but I was seen screenshots and videos from other MSi.SDR owners and it shows the same issues. And their owners don't notice it, just because don't know how it should works or just don't have other radios to compare with...
So, at least half of issues that I know are present on other MSi.SDR instances and some issues was confirmed on genuine RSP1
It's more likely that you're just had good lack and get instance that works well, not like others. But I suspect that you're not very demanding and are not used to high quality sdr radio, so you're simply do not notice all these issues
If you have MSi.SDR, we can test it, just let me know if you're ready to do test, I will prepare for you settings, you will record wav file with IF from your MSi.SDR instance and share it here, I will check if your device has these issues or not. So, we can check if you have the same "perturbation source"
As a start point you can do this test:
https://www.eevblog.com/forum/rf-microwave/cheap-msi-sdr-(sdrplay-rsp1)-clones-anybody-have-one/msg3158922/#msg3158922I was wondering if you had done this, Ive been thinking about getting a "malachite" which uses an msi front end, and was wondering what its weak signal performance looked like to somebody with a lot of HF experience. (with external antenna of course)
Malachite uses MSi tuner chip only and capture it's output with audio ADC, it don't uses MSi receiver chip. So, this is not correct to compare it with MSi.SDR or RSP1, they using different SDR stack. But it is well known that Malachite has frequency gaps and worse sensitivity than other portable sdr radio.
You can find sensitivity and dynamic range comparison of Belka with Malachite on youtube.
