Author Topic: CC112x LNA Balun Extra component  (Read 1542 times)
Offline veryevilTopic starter
« on: May 02, 2017, 03:56:49 pm »
Hi, I'm looking into matching a CC1125 to a Skyworks  SKY65366-21 (or 11) at 459MHz and I'm trying to understand the LNA Balun from all of the TI Reference designs.
In the attached picture I don't understand the purpose of L191.
I understand the 4 component balun but not why there is an inductor between the positive and negative inputs on the balanced side?
The pic is from the 420-470MHz ref design.
Thanks
Re: CC112x LNA Balun Extra component
« Reply #1 on: May 05, 2017, 12:46:08 pm »
Apparently its to provide the LNA transistors with a DC Ground path.
No idea how its calculated an d it surely must effect the balun values.
Offline BigBoss
« Reply #2 on: May 10, 2017, 12:58:25 am »
A kind of matching has been used in order to compansate the reactive part of the internal LNA.
Noise matching is another possibility..
